If the spark isnt hot enough it will have a hard time igniting gas, but starter fluid doesnt need much to fire. I would avoid using starter fluid if poss. Use chemtool carb cleaner. Less likely to do damage to engine.
When you checked spark at the plugs what color was the arc ? Should be blue. If you can get another distributor, try it and see if it fixes the issue.
