hey guys and gals, here's the back story:
I own a 84 22r lifted locked all that jazz. i just had my head rebuilt 2 weeks ago installed it and the truck has ran great!! on Thursday i headed from Pleasanton, Ca to Colfax, Ca. its about a 3.5 hr drive. i had no problems the entire way but whence i arrived at the lake it began to run horrible barely keeping an idle. so here's what i have done to try and figure out whats wrong:
-i pulled plug wires as it was idling starting with wire 1 when i pulled them each time it ran worse Except for when i pulled the #3 plug wire there was no diff. so i said, must be running on 3 cylinders.
-next i made sure i had spark at each plug and they all have spark.
- next i ran a compression check ALL 4 cylinders have 180.
-now i decided to get a go-no-go gauge and check my valve adjustment all spot on to factory spec.
- i also checked my timing with a light dead on.
i am totally baffled at why it would be running so bad when everything seems to be in order.
any tips y'all would reccomend to help figure out this issue would be great, i am gonna call the machinist that did the rebuild this week but i am hoping there is some other thing to check b4 i take the head off the motor again.
THANKS IN ADVANCE!
-TREAD LIGHTLY-
