Author Topic: Dual cause hum/howl  (Read 2320 times)
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
Dual cause hum/howl
« on: Jul 29, 2011, 07:52:13 PM »
Ok, I just got done putting in my duals, stock gears in both cases. Both cases were in working order. But now above like 20 mph either the crawl box or transfer case starts to do a howl, it's the worst around 30 mph then it gets quieter but can still be heard up to free way speeds, doesn't get louder at freeway speeds though. Any ideas where the howl is coming from?
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Re: Dual cause hum/howl
« Reply #1 on: Jul 29, 2011, 07:56:12 PM »
is it fullllll of oil?
Nimyad [OP]
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #2 on: Jul 29, 2011, 08:36:29 PM »
Yeah filled, started and let spin for about 5 minutes checked and filled again, then hooked up driveline, drove about 10 miles then checked and filled again
Nimyad [OP]
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #3 on: Jul 29, 2011, 10:50:22 PM »
Ok so drove it some more. The sound is like when you spin metal inside of another metal sleeve, that high pitched weird noise. It mostly does it when decelerating
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
« Reply #4 on: Jul 30, 2011, 08:05:42 AM »
It could be your output bearing on rear case.  You can pull the rear part of tcase, then remove the lock ball, then the 2 speedo drive gears.  After that the output bearing will come off.  May take a few a little prying but it will come off.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Jul 30, 2011, 08:37:10 PM »
sounds like a thrust washer didnt get a snap ring
Nimyad [OP]
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #6 on: Jul 31, 2011, 12:13:36 AM »
Well I was thinking it was a bearing but there's no consistency to it. It'll be there one minute then go away for about 10 seconds then come back, sometimes it's quieter sometimes it's louder.
All snap rings were installed, the rear case is 100% factory never been opened, less then 100k miles. The crawl box has 170k miles on it, bearings were fine. The only thing I could think is that I had to switch the flanges on the rear case, could putting them on to tight cause this?
Also I finally decided what it sounds like, it's the same sound and pitch as when your ears are ringing
PhantomD aka Zach
  • Male Posts: 210
  • Member since Jun '09
  • Needs more garage space!
« Reply #7 on: Jul 31, 2011, 12:33:39 AM »
main bearing...
had a very similar issue, check the double row bearing, probably ate the cage and is creating all sorts of havoc...
but seriously, pull the cases apart until you cause more damage.
3rd Gen Extra Cab, Dual Cases, E-Lockers
Nimyad [OP]
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #8 on: Jul 31, 2011, 12:15:59 PM »
Ok lifted up the rear tires and took it up to speed. Found out it's the rear ring and pinion not the t case thankfully. So I'll tear into that this week sometime
Japjeep
  • Turtle Points: -23
  • Male Posts: 119
  • Member since Oct '10
« Reply #9 on: Sep 19, 2011, 04:39:57 PM »
r u running a rear cv driveline?
Nimyad [OP]
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #10 on: Sep 19, 2011, 06:42:58 PM »
Nope
Japjeep
  • Male Posts: 119
« Reply #11 on: Sep 19, 2011, 07:35:16 PM »
i just did the same thing and my cases sounded like they were going to grenade (but only after installing duals)when i let off the accelerator after 40 50 mph. after info, replaced ujoint with cv and noises all gone! weird! but actualy turns out pretty comon.
Last post Jun 23, 2008, 06:55:16 PM
by Rockcrawlintoy
Last post Dec 15, 2008, 05:33:14 PM
by scyota
Last post Jan 04, 2010, 09:46:56 AM
by dntsdad
Last post Jul 17, 2010, 06:58:18 PM
by dk98
Last post Aug 28, 2011, 08:52:35 PM
by sweetmeat
