welding sliders
Started by Michael Wollinsky, July 27, 2011, 08:13:03 AM
Michael Wollinsky
Which is best to us arc weld or mig or tig? I have the option of all 3
Hand built and driving daily
howyadoin
Quote from: ol blue on July 27, 2011, 08:13:03 AM
Mig should work great and is simple.  I definately wouldn't waste the time with tig.  Obviously, fab up some frame plates to distribute the load when welding them on.  .02
"Flexes like a boneless hooker on muscle relaxers"
Michael Wollinsky
So there's no point in trying to use a arc welder
fordh8r
Arc welder will work just fine as long as you are comfortable in using it to achieve satisfactory welds. Just be sure to choose a good rod and make sure the rod isn't old where the rod coating could be moist. Fresh dry rod will work best.  :thumbs:
Michael Wollinsky
OK just making sure I'm better at arc welding
_HOIST_
x2 on whatever you can create the best quality welds with. Make sure you can trust having quite a bit of your rig's weight sitting on them if you get hung up.
junya92toy
Weld with the best way you can, all 3 are arc welding.
