tire wieght and wheel weight specs
Started by superyota, July 25, 2011, 11:07:45 AM
superyota
If you know what the wheel and tire weight is on your current setup, please post up details of wheel specs and tire specs.  Here is what I have right now.
15x8 allied 32 bolt beadlocks, 2.5 inch b.s. - 34 lbs each
39.5x13.50x15 irok radials - 96 lbs each.
total = 130 pounds per corner x4 = 520 lbs.
I'll modify the tread and get a list of that is organized up once I get more specs on other wheels and tires.
TIRES:
Interco:
-Irok Radials
  39.5x13.50x15 - 96 lbs
-Bias Ply Irok
  39.5x13.50x15 - 76 lbs
Toyo:
-MT's
  37x14.50x15 - 93.7 lbs
WHEELS:
-Allied
  32 bolt beadlock
    15x8 - 34 lbs
-Cragar Soft 8's
  15x10 - 34 lbs
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Dingman.
I have black steelies, and 37" toyos.
I don't know if i want to know how much all my tires weigh
superyota
Quote from: Dingman. on July 25, 2011, 12:52:40 PM
lol.  what size wheels? and whats the width and wheel diameter on the tires?
ABD Motorsports
#4475
KK6QDW
Dingman.
Um 15x10 3.5" bs i believe.  Black steelies, soft 8's
37x14.50x15 toyo mt's.
Toyo's websit says 93.7 pounds per tire without wheel.
I don't know though.
My toyos feel like they have concrete weighing them down compaird to my old 39.5" iroks on beadlocks..  :dunno:
Dingman.
interco's site says the 39.5" irok only weighs 76 pounds per tire for the bias, which is what i had.
I didn't realize the radials weighed so much more.
superyota
... from jegs.  this should be close enough to your setup.  this is for the soft 8's with a 4inch backspace...
15x10
Wheel Size 15x10"
Wheel Height 15"
Wheel Width 10
Offset -38mm
Bolt Pattern 6x5.5"
Back Spacing 4.00393"
Weight 34 lbs
wow.  our setups are almost the same weight.  yours totals (34+93.7)x4=  510.8 lbs.
ABD Motorsports
#4475
KK6QDW
Dingman.
Wow. So 508 pounds for all 4 tires i guess.
twistedtoy92
Allied 15x10 Soft 8 steel wheels- 34 lbs
39.5x13.5x15 Bias Iroks- 76 lbs
110 lbs at each corner plus the spare.... 550 lbs
