Or if it's going to fail, fail at home after the smog test is complete....
![Yup yup :yupyup:](https://board.marlincrawler.com/Smileys/marlin/yupyup.gif)
I was putting my truck back to pre-smog test specs (advanced timing, low idle speed) when I noticed that the tach wasn't working.
Shut the engine off, and restarted it.
It was fine.
![Willy Nilly :willynilly:](https://board.marlincrawler.com/Smileys/marlin/willynilly.gif)
Check engine codes, and it's flashing 'ignition signal'
Start engine, no tach again...... then engine shuts off and won't restart.
![Sad :(](https://board.marlincrawler.com/Smileys/marlin/sad.gif)
Bypass MSD ignition (with those jumper cables at the coil) and all is fine with the stock ignition.
![My Two Cents :twocents:](https://board.marlincrawler.com/Smileys/marlin/twocents.gif)
I really hope it's the little coil like adaptor you need with toyota ignitions with a MSD, and not the MSD itself...........
![I Dunno... :dunno:](https://board.marlincrawler.com/Smileys/marlin/dunno.gif)
Now to find an old coil, or something I can use as a coil for some testing.
