electical short?
Started by jackson58, July 23, 2011, 03:10:09 PM
jackson58
 I had thought my key switch had been a problem when I turned the key I didn't get anything. If I used a jumper wire on the key switch it would turn over. I then replaced the key switch, at this point I still have to use a jumper wire to turn it over. I had my ground for my cigarette lighter short and was wondering what could be damaged up stream? I replaced the melted section of wire. I have checked all my fuses and replaced a couple relays but still nothing.  :hammerhead: :inthedark:
Dirt is for wheelin not for wearin you filthy hippie!
crazykooter
Have you checked the fusible links by the battery ?
jackson58
Sure did in hopes it would be that simple
brainlessfool
does ya knows how many power leads come into the ing. switch? might be more than one hot wire.
if that's the case you've more likely lost power on one.  :crossed: need a wire diagram.
jackson58
Found that my whole wiring loom is melted.
crazykooter
Ouch  that sucks bud.  Im sure you can repair it or find another harness.
jackson58
I thought about repairing it but probably will be easier to buy another. So if anybody has a good source on a 85 harness let me know please
jackson58
Does anybody know if a 88 Toy dash harness is compatible with an 85?
bigarms23
if the 88 is a efi 4cyl and the 85 has efi than it should be compatable
jackson58
