Author Topic: Broken bolt removal -  (Read 2518 times)
Redeyejedi
  • Male Posts: 115
  • Member since Jan '07
« on: Jul 21, 2011, 12:19:50 PM »
i am cleaning up the knuckles to prepare them and i noticed a bolt broken off. any suggestions on how to remove it?
alcohol.....the cause of, and solution to, all life's problems
http://www.flickr.com/photos/78234902@N06/
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • Member since Nov '09
  • San Diego, CA
Re: Broken bolt removal -
« Reply #1 on: Jul 21, 2011, 12:24:49 PM »
Buy a broken bolt extractor. The one I like is a Snap-On that uses reverse drill bits and an extractor.
1985 Toyota 4Runner, BFG 35" MTs, 4" lift, Detroits lockers front & rear,5.29, V6 rear, rebuilt 22RE.
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
    • Placer County Crawlers
« Reply #2 on: Jul 21, 2011, 12:56:51 PM »
easy-out, or at least thats what I've always known them as.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
« Reply #3 on: Jul 21, 2011, 01:05:59 PM »
with one of these guys,   you can find them by the drill bits at any hardware store.
You just drill a tiny hole in the bolt, tap it in then unscrew it.
http://www.toolking.com/1/hanson_52401_spiral_flute_screw_extractor_ex_1_1051662720.php
Tofudude
  • Turtle Points: -31
  • Member since Jun '10
« Reply #4 on: Jul 21, 2011, 01:10:44 PM »
i think you'll need a reverse tap to do that
86rustbucket
  • Turtle Points: 45
« Reply #5 on: Jul 21, 2011, 01:14:59 PM »
No I mean you just tap the extractor in with a hammer after you drill a small hole in the center of the broken bolt.     then turn it
Redeyejedi [OP]
  • Male Posts: 115
« Reply #6 on: Jul 21, 2011, 01:54:09 PM »
thanks, appreciated!
picked up a set. going to see what progress i can make on it.
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
  • Member since Nov '08
    • oppiz.net
« Reply #7 on: Jul 21, 2011, 02:01:04 PM »
Before you start spray it with some penitrating fluid the night before.
If you see it, its for sale.
Redeyejedi [OP]
  • Male Posts: 115
« Reply #8 on: Jul 21, 2011, 02:47:11 PM »
got it!
thanks guys! :thumbs:
i don't know why in my mind i thought yall were talking about these, and im like how do i use them here?
so to sum up...
after i posted originally, before i left to get the extractors, i heated the bolt up a bit, then sprayed pb blaster and ran a candle on it to allow wax to get sucked in with the penetrating catalyst.
it soaked for aprox 35 min.
went at it with the drill bit, broke one, but got to the bottom.
used the extractor and out it came, 8sec, with minimal effort.
thanks again.
:cheers:
zippo
  • Male Posts: 1,557
    • oppiz.net
« Reply #9 on: Jul 21, 2011, 03:38:47 PM »
PB Blaster is where its at....
nonwing
  • Member since May '09
« Reply #10 on: Aug 12, 2011, 07:16:39 AM »
Soak the bolt with a 50/50 mixture of acetone and ATF for a day or more, then try drilling out with a left hand drill bit.  McFadden Dale Industrial Hardware sells these bits for around $5.00, but you have to ask for them as they are kept behind the counter, at least at the store I go to.  Usually the broken fastener will start to spin back out with the drill bit without damaging the hole.  Has worked for me very well.  Depending on where and what you are trying to remove heat works also.
Last post Jul 07, 2007, 11:44:40 PM
by Prismo
Last post Jul 04, 2007, 01:57:23 PM
by CTENG in KS
Last post Sep 14, 2012, 08:16:17 PM
by kneedownnate
Last post Oct 08, 2013, 05:47:25 PM
by moutaintoys
Last post Sep 13, 2014, 07:46:49 PM
by gigalo
