MY "SHORT FUSE" BUILD UP
Started by 1SAWB, July 15, 2011, 01:51:53 PM
1SAWB
WELL THIS HAS BEEN A LONG ON GOING PROCESS. BACK IN THE MIDDLE OF 2007 I  FOUND AN 85 STD CAB EFI TRUCK THAT THE GUY WANTED $1200.00. I CALLED SET A TIME TO CHECK IT OUT. I SHOW UP AND THE GUY ANSWER'S THE DOOR AND SAYS HEY I'LL TAKE $800.00 FOR IT IF YOU WANT IT . IT WAS SUPPOSED TO HAVE A NEW ENGINE. AND HE DIDN'T KNOW MUCH MORE AN THE TRUCK HAD A SMITTY BUILT INTERIOR CAGE BUT IT HAD BEEN ROLLED IN IT'S LIFE  :smack: I CHECKED IT OUT AND ALL THE PARTS WHERE THERE. SO I PICKED IT UP  :thumbs:
87 EXTRA CAB ON AN 85 STD CAB FRAME 1 TON'S, DUAL CASES 2.28 FRONT 4.70 REAR, LONG OUTPUT, 40'Z AND I DON'T NEED NO STINKIN CAGE MANG
1SAWB
I GOT IT HOME AND TOOK IT DOWN TO THE FRAME AND STARTED THINKING ABOUT WHAT I WANTED. A LOCAL GUY SOLD ME AN 87 EXTRA CAB TRUCK COMPLETE FOR $20.00 WITH TITLE  SO THE WIFE AND I SWAPPED THE CAB AND REAR END OVER TO THE STD CAB FRAME. NOW THE STD CAB WAS AN SR5 SO I SWAPPED THE WIRING HARNESS TOO.BUILT A BED THAT IS THE WIDTH OF THE CAB AND TAPPERS TO THE WIDTH OF THE FRAME. AS I WAS SWAPPING THE REAR END TO THE WIDER 87 REAR I FOUND OUT THAT THE 85 HAD 5:29 GEARS  OH HAPPY DAY ONE LAST THING TO MESS WITH. AND  THE GEARS IN THE REAR WHERE JUNK SO I ORDERED MORE.I REBUILT THE WHOLE FRONT END SWAPPED IN THE IFS HUBS FROM THE 87 AND BOUGHT V-6 CALIPERS AND LC ROTORS, INSTALLED A DUAL DIAPHRAM BOOSTER AND PUT IN A GM MASTER KNOWING ONE DAY IN THE FUTURE I WOULD HAVE 1 TON'S UNDER IT. SWAPPED IN 7 LEAF WAGGY SPRINGS IN THE FRONT AND WELDED IN A NEW FRONT SPRING MOUNT ( FACTORY ONE WAS FAWKED FROM THE ROLL). THIS IS HOW SHE LOOKED WHEN IT WAS DONE
I COULDN'T HANDLE THE COLOR'S SO I PAINTED IT IN MY DIRT DRIVE WAY
AND HERE IS THE FINISHED PRODUCT
1SAWB
THEN I TOOK IT OUT WHEELING
NOTE THE NO MORE STINGER. DAMN THING WOULD ALWAYS HANG UP ON STUFF
I ADDED DUAL CASES WITH BOBBY LONG OUTPUT, TRIPLE DRILLED FLANGES 4.7 MARLIN GEAR'S IN THE REAR.
THEN I NEEDED TO CHANGE THE REAR SPRING'S WAY TO STIFF. SO I WENT TO SOME F-150'S AND LOVE THEM WHILE I WAS AT IT I ADDED REAR DISC BRAKES  :eyebrow:
HERE IS A SHOT OF THE TESTING
NOTE THE REAR TIRE STUFFED INTO THE BED
SO NOW I CUT THE HELL OUT OF THE BED
LilChief87
sick looking truck i like alot good job ill be keepin a eye on it  :popcorn:
87hillbillyoter
nice truck, i like the color. but PLEASE turn your caps lock off, it makes it really hard to read
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
1SAWB
after cutting the hell out of the bed the rear tire cleared much better. i took it to K.O.H. 2010 and wasn't happy with it so i drug it home in hopes to find 1 ton axles. one night when i could sleep and around 2:00 A.M. i was on my phone cruzing Craigslist and found a guy parting out a 1 ton chevy 4x4 that had just been posted. i sent an e-mail and instantly got a response. that he wanted $300.00 for the Dana 60 front  :biggthumpup: so i jumped on it. the next day i was a proud owner on that 60. i tore it down and narrowed the long side 3", rebuilt it and waited for a rear. i came across a 14 bolt with brand new gear's,detroit and Ballistic cover for basicly free  :yikes: so i snagged that up. geared the front to match and added a spool ( i know but money tells when what to run) i traded some stuff for cromo stubs, yukon super joint's and an install kit. while i was there i added C&M machine bronze upper bushing's in the king pins. ordered my yokes to go to toyota drivelines . wfo cross over steering stuff and started making it happen....here are a few pics
SHE'S UNDER !!  :yupyup:
1SAWB
SWAMPER  MOCK UP
REAR
now it was finally on it's own weight with the 40'z and teh one ton's. i had also obtained a set of prerunner fiberglass front fender's that i knew would look killer so i squirted some paint on them that i had left over from when we painted  and here she is
stock fender's
PRERUNNER FENDER'S
LilChief87
the last post the pics arent showing up but lookng killer
1SAWB
now that we are finally up to date with this thing.
i got the brake line's all finished this past weekend and took it out for a little testing in the field  down the street mainly to see where i wanted to set the shock's up at . here are a few poser flex shot's and with both new front fender's installed
1SAWB
