diff stud eliminator?
Started by FRANKENYOTA91, June 18, 2011, 02:57:01 PM
FRANKENYOTA91
Does anyone know the size and thread pitch of the bolts used?
85 toy double extended cab pos wheeler bobby longs, welded front and rear, dual cases
89 4runner sas,  duals, the usual
81 toyota long box project
83 short box project
2001 Cummins 6 speed tow rig
is this a trailgear product??
pretty sure it is 8 x 1.25"
i wouldn't kmow about being a trail-gear product, but.... some people install studs instead of bolts to retain their diffs into the housing, and they just use standard nuts and bolts
yota_krawler
Quote from: 79coyotefrg on June 18, 2011, 06:38:20 PM
Haha
The rock assult stud eliminator
Lol I think he wants to get rid of the studs and nuts, and go with allens?
4RunnerChevy
Stud eliminator, sounds fancy for just getting a bolt and putting it in.  I would just pull a stud and go to the store and buy a bolt, maybe get fancy with an socket head pan. Stainless even  :shocking:
Dr Phat
yota_krawler
Stainless... Oh :pokinit:. I agree, just double nut it and get yourself some new bolts or allens
Stainless allens would be :bling: just sayin. I might do it to mine!
FRANKENYOTA91
Yes trail quee makes it but I wont buy it from them. I just want to run Allen bolts and I would pull one stud  and go buy bolts but I don't have any studs. So all I need to know is what size they are.
John Doe
Jimbo had it right, its 8 x 1.25 then however long you want it.
Quote from: FRANKENYOTA91 on June 19, 2011, 08:38:06 PM
8m x 1.25 x 30mm long (30mm is an approx length from memory)
toyotaporvida
I'm looking to doing the same and what I've read so far you want 8mm x 1.25pitch x 40mm button head studs
cruzila
I bet those are $30.00 a hundred for the bolts from a hardware wholesaler. Nuts, $15.00 a hundred. $45.00 and you can do yours and 9 friends too.
PhantomD aka Zach
my buddy built a couple kits from fastenall, very easy and works great, he runs them on his and his wifes trucks, and I have them on mine...
it was stupid cheap too.
-Zach
3rd Gen Extra Cab, Dual Cases, E-Lockers
FRANKENYOTA91
Thats why im looking at just buying bolts. way cheaper than buying trail queers kit.
Doof
its pretty easy to do. i did this with my toy axles, drilled out the holes to like 3/8th i think it was. cut the dif cover off, tacked the button heads, put the nut on it and massage is with the slug-o so they all line up, bolt the 3rd in with carrier, and some good weld on the button heads to keep them in place. took a few hours when all said and done but it was worth it
Quote from: Doof on July 18, 2011, 08:52:30 PM
...cut the dif cover off...
Are you saying you made a removable access cover like a Dana style axle for instance?
_HOIST_
I believe the diff cover was cut off so as to gain better access for tacking the bolt heads and then welded back on. I saw a writeup on Pirate(?) I think. I'm don't know if this is Doof's or not though, just one that I came across.
EDIT: Here is is http://pirate4x4.com/forum/showthread.php?t=485834&highlight=stud
Ah, I C, thanks for the link, that is pretty cool
Doof
Quote from: BigMike on July 21, 2011, 08:39:49 AM
thought about doing something like that, but given my time frame to get it done i didn't want to deal with it. but i used the plasma to cut the front of the diff off so i could get some good heavy tacks on the allens. after i had all the bolts tacked and straight i welded the cover back on. it looks factory and if you didnt know what i did you would never be able to tell i re-welded it unless you really got down and looked at it. its really simple and if you are going to do the allen's i highly recommend doing this if you have the tools, skills, and common sense  to do it correctly
Sparkplug
thats a pretty sweet mod, im betting its around 20 bucks in hardware though, and then some time, but man, thats beef and IMO looks killer, im gonna give it a try on a housing here soon
