Feeler: 86 4runner
Started by foxtrot89, May 28, 2011, 05:41:09 PM
foxtrot89
putting a feeler out for my 86 4runner. Only reason for selling is I am going into the Air Force and cannot bring it with me. It has been a great truck and has done some of the harder trails in Colorado. Located in Colorado Springs, CO. starting price of $4,500. here is a list of the mods:
86 4runner
22re with 5spd
Solid axle swap
5.29 gears
marlin crawler high steer knuckles with all pro 1 ton tie rod and FJ 80 ends
long travel shocks with ford F150 shock towers
chevy rear spring conversion and helper springs up front
37 inch MTR's on 15" rims
smitty built front bumper
rock sliders
all seats out of a 91 runner
altimiter and roll guages
cb radio  setup for dual antennas
front square driveshaft
Drag Link - 33 1/2" w/ends & jam nuts from all-pro
onboard air compressor
rear aussie locker
Front Aussie locker
Dual transfer cases (stock gearing)
TG crossmember
rear DS re-sleeved with .095 tubing vs stock which is .06x
gas tank skid plate
axle gusset and diff armor
Rear window no longer works, I have given up on troubleshooting these things
carpet removed
door hinge mod where you can just loosen the bolts and lift the doors off
optima red top
just did tune up new dist. cap, rotor, wires, plugs, oil change, and radiator flush
comes with an extra set of 36" military tires/ 16.5" rims with cracking in the sidewall but hold air fine. about half tread left
comes with a roof rack not yet mounted
pictures:
1989 Toyota 4runner - 22RE 265xxx miles, 35"tires, 5.29 gears, aussie locker in the rear, marlin 1600 lb clutch, still starts and runs like a charm
