failed t'case mount- option other than stock?
Started by crawler#976, October 28, 2002, 06:15:49 AM
crawler#976
hey guy's-
This weekend, the rubber stock t'case mount failed, even w/ the motor mounts chained. The C/V's knockin' on the crossmember every now and then  :greengrin:
Priced out a NAPA replacement today at $114.75 and OEM from Toyota at $99.52
Anyway, I wondered if anyone has fabbed up one? I'm thinking about building one similar to a leaf spring eye/mount using standard bushings and 5/8's hardware.
Any thoughts, Comment's, or Suggestion's would be appreciated.
Mark
SAS'd '87 w/ tested exo'd cab, and crawler#976
Brandon
#1
PnP ;)
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
crawler#976
#2
hey Brandon,
wish we had a good one here- but indeed, the PnP's up here are JUNK yard's. It's rare to even see a Toy in one. Even if they DID have one, they'd want $115.00 for it  :smack:
I'd also like to make something less prone to failure- I'm used to the vibrations from chained down motor mounts, so whats a little more buzzzzzzzzin', right?
later
Brandon
#3
hard mount it to a custom crossmember, and put a bushing on the crossmember to the frame - same idea as the front range crossmember..
Brandon Miller
Brandon
#4
I made my own crossmember, but used the stock rubber doohickey
I don't think they will move if the engine ones don't, and my engine ones are like you said - bolt through a bushing style - won't break..
Brandon Miller
crawler#976
#5
" hard mount it to a custom crossmember, and put a bushing on the crossmember to the frame - same idea as the front range crossmember.. "
______________________
hum, that could be an option-
I've got an All Pro dual t'case cross member-  I guess I'm gonna have to drop the whole mess and see what my options are.
later
cruzila
#6
Budbuilt has a different one. check em out
