Cheap tricks
Started by rEdnECkwHeE1eR, August 15, 2002, 10:54:52 AM
0 Members and 45 Guests are viewing this topic.
rEdnECkwHeE1eR
This is the place to post ANY cheap trick.
For example fliping the air boot thing that comes of the air filter container(does any body have the correct names) around so the air is drawn from the back of the engine compartment insted of right by the head light. Im not sure all the years you can do this but I think its atlest on 79-83s.
Liquor up front
Poker in the rear
grease_monkey
#1
If its cheap post a pic of your self :moon:
1987 X-Cab
hawaii500_1999
#2
i know a cheap trick.
rear end vents.
go to a wrecking yard and get the barb fittings off of the in take manifolds on 22r's or 20r's for the brake assist hose.  they screw right in the old 8" axle housings on my 82.  then run fuel line way up high.  i stuffed the OEM breathers in the ends of the hoses too.
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
rEdnECkwHeE1eR
#3
We accually havent done it yet but it will be one of the next mods for the ol' toy.
Liquor up front
Poker in the rear
rEdnECkwHeE1eR
#4
The breather trick is also coming soon.
Liquor up front
Poker in the rear
Brandon
#5
eaiser to go to home depot if it is closer and get a brass pipe thread, close enough to metric - works great..
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
rEdnECkwHeE1eR
#6
VW Bug fuel filter! :headshake:Yeah it works my buddys fuel filter was cloged so bad that fuel couldnt pass through. We called his dad, a VW mechanic, and he brought home a VW fuel filter. Now your wondering why not just get a TOYOTA fuel filter? Well these things cost under $.10 and you can see the fuel go through it. You can also see if its cloged if you instal right. IN<Out.
Liquor up front
Poker in the rear
rEdnECkwHeE1eR
#7
There is a cone shaped filter inside the clear can looking thing run the fuel against the cone (IN<OUT) so you can see if the filter is filling up with crap. Im not sure if it will work for every year but it will probaly work with more then just toys :beer:
Liquor up front
Poker in the rear
hawaii500_1999
#8
Quoteit will probaly work with more then just toys :beer:
i use those on my motorcycles when i ride them in the sand.
rEdnECkwHeE1eR
#9
Quotei use those on my motorcycles when i ride them in the sand.
:.order: :.order: :.order:
Liquor up front
Poker in the rear
cruzila
#10
Air tanks. Big truck wrecking yard. A friend got two 3-4 gallon tanks a zillion fittings, pop off valve, one way valve, for 25.00 a few years ago.
cruzila
#11
Need new wheels?? Americas Tire. 28.00 for 8x15 white spoke. 10.00 to have made 2" backspace.
cruzila
#12
QuoteThis is the place to post ANY cheap trick.
There is an access panel for the wipers on the firewall. plumb intake air into it and draw cool air from there. Who needs a snorkel??
rEdnECkwHeE1eR
#13
My friend is using a keg for an air tank.
Liquor up front
Poker in the rear
hawaii500_1999
#14
i saw this earlier today.
http://www.off-road.com/toyota/cheaptricks/
i didn't read them all but the one's i read looked cool there is even one from marlin.
e_cliff
#15
there is colder air next to the head light . the air in the back of the engine compartment is hot becaus there isn't any air flowing there and its by the exaust manifold.
one cheap trick is to use the rear rubber brake line in the front( one for each side) there male/female
Cliff
5spd
#16
Heres one also...pull the switch out for the power windows and run a jumper then you can power up and down without having the key in.
 Another...splice into the rear window lines and put a switch in it so you can power up-down when you sleep in the back...mount the switch on the rear panel...4runner only.
 Wait..1 more...fine your gas pump line under the pass door channel and splice a switch into that also...hide it and you can turn it off and the vehicle wont start without the pump...
 Wait...1 more...splice a battery cut off switch between the battery and starter...key stylr...hide it...must have key in and turned to start...no key no start..
 Wait..1 more...extend your brake line when lifted..connect 2 lines together...works front (need a nipple 2ea) and rear
 Wait...1 more...nissan, toy vaccum or 1/8" brass line nipple for your diff breathers...yup and a VW gas filter for the end..
 Wait....ok going to bed now.....LOL
cruzila
#17
An even cheaper trick is to use "used" VW filters for the end of the breather hoses.
hawaii500_1999
#18
pilot bearing removale.
thought of this when i was doing it last weekend.
use your clutch alignment tool and pack the cavity in the crank behind the pilot bearing with grease.
use the allignment tool tip and tap it in with a hammer.(not hard you don't want to wail on your crank.)  it will just push in easy at first but the cavity will eventualy fill with grease and you just tap and pack with grease and tap and so on.  the hydrolic force will push that bearing right out.
i have had some seals pop out on me,(on sealed bearings).  so it doesn't all ways work but for the most part it has.
hawaii500_1999
#19
as for a clutch alignment tool i don't have one i use a punch with a shop rag wrapped evenley around it.
guess i'm just a back yard mechanic. :thud:
mr4x42u
#20
For those of you that still have the carbed 22r.If your fuel pump ever fails you can get a few miles back home still.I had mine fail once so i drained my windsheild washer bottle of the water and filled it with fuel.Ran a washer hose to the bowl vent in the top of the carb and filled it as I drove from thw washer switch.Its slow and distance is not far but better than walking! :up: :up:
