96 t100 sas what do i need?
Started by T-100 tank, April 04, 2011, 10:08:17 PM
T-100 tank
Hey hows it goin all. i got a 96 t100 4x4 stock "at the moment". I got sas on the brain. However i need some help on what i need. Im gonna go Dana 44 in the front keep the stock rear axle. I wanna do 5:29s and im planning on running 39.5 iroks. I havent even begun buying any parts yet because i want to get some opinions on what to do. Im thinkin about just buying a built dana 44 so i dont have to set up gears and what not. Thanks for the help in advance
golana
what kinda wheelin do you want to do?
-Steve
1994 4Runner - BUILD THREAD
5VZ-FE - 12" Lift - High Steer - Hydraulic Assist - IFS Mod - Scuba Mod - Ford Fuel Tank - E-Fan - Doubler = 96.31:1 Crawl Ratio
Brake setup
FRONT: 98 Tacoma Rotors/Brake Master Cylinder/Booster, 94 V6 Pickup Calipers, 86 IFS Hubs
REAR: 85 Solid axle Rotors/Calipers/Lug Studs, 1/4" Wheel Spacer
T-100 tank
Well i go up to the high lakes pretty much every weekend in the summer. i dont wanna wheel anything too crazy the farthest i will probably go is to morris.
yotaneck13
what ever you do make sure you have a complete plan out of the build and everything you want to accomplish too many build start and stall real quickly causing them to spiral downward becaust the builder didnt plan it out accordingly losts of reserch here as well as other 4x4 forums will help loads in the long run there are plenty of t100 sas builds on here to look over and see the problems others before you have run into so you do not have the same this will result in a much smoother build with minimal down time with that said
get some reserch done and start wrenching im hooked on any and all T100 builds i started mine last winter but put it on hold to build my 90 reg cab i am going to change directions with the t100 i believe i have plans to make it the ultimate tow rig now after my 90 is completed :thumbs:
GOOD LUCK
golana
i have no idea what kind of wheeling is up around that area... i live up in the rockies, and we have a little bit of everything. my favorite is rocks and mud though haha!
hit up pirate for some good knowledge, thats where i got a LOT of the info for the stuff that ive done to my truck...
-Steve
Brake setup
