Crossover steering from the junkyard
Started by Volcom, January 20, 2005, 07:08:24 AM
Volcom
I found a 87 Toyota 2WD truck in a pull-and-save and it's got crossover steering on it.  My 85 PU is manual steering and I want to convert it over.  I've got an IFS box, PS pump and all the hoses.  Will that 2WD steering work?  If so, what do I need to pull from it?  How do I connect my current steering arms to the crossover steering linkages?  Sorry for the newbie question  :smack:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
88runner
OK, what's you definition of crossover steering  :confused:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
mplatzer
IF YOU DONT WANT TO MESS WITH IT I HAVE CROSSOVER STEERING THAT I AM SELLING IF INTRESTED CALL MIKE @916-871-0747
BACK TO THE QUESTION  IN ALL MY DAYS OF GOING TO THE JUNK YARD I HAVE NEVER SEEN ANYTHING 2 WHEEL DRIVE THAT HAD CROSSOVER STEERING. BUT IF IT DOES THE TIE ROD AND DRAG LINK WOULD NOT BE TO THE STRENGTH OR CALABER TO WHAT YOU WANT TO PUT ON A ROCK CRAWLER. THIS IS A INTRESTING QUESTION AND TO GET MORE RESPONSE WE NEED TO KNOW MORE DETAIL :welcome:  :beer:
HAMMERS THE BEST TRAILS IN THE WORLD
Volcom
Quote from: 88runner on January 20, 2005, 08:54:27 AM
huh, not push-pull  :wag:   My crossover steering defn. is whatever came on the 86+ stock 4x4's and what I thought 4x2's.  I'm most confused on how the crossover drag links and tie rods connect to my current steering arms?
mplatzer - what's included in your crossover steering that your selling?
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
88runner
you cant attach the tierods directly to your current steering arm you need to find another pass. side arm and weld it on top of the other.
you have the ifs box and power steering pump
what does the 2wd parts have to do with crossover steering, this is where you confused me.
88 4runner v6,
solid axle'd
Volcom
Quote from: 88runner on January 20, 2005, 10:17:18 AMwhat does the 2wd parts have to do with crossover steering, this is where you confused me.
The drag link and tie rod.  Will those work?  Thanks for the replies and the heads up on the steering arms.  :thumbs:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
88runner
well you see the 2wd as the same kind of steering systeme that the 4wd ifs use so no it won't work
a ifs steering system is like this:
           idler arm________________________pitman arm (atached to the steering box)
                     to the                              to the
                     knuckel                             knuckel
crossover:
      knuckel -----------------------------------------------ifs box
  (pass. arm)_____________________________driver arm
88 4runner v6,
solid axle'd
88runner
Best thing to do IMO is to get high-steer kit, but plenty of people run crossover. :beerchug:
88 4runner v6,
solid axle'd
Volcom
Quote from: 88runner on January 20, 2005, 12:36:46 PM
                     to the                              to the
                     knuckel                             knuckel
crossover:
Ok, those diagrams helped a ton!   :beerchug:   I understand the difference between stock IFS crossover and what everybody else calls crossover.  I would love to setup hy-steer but I was hoping to get this powersteering thing done cheap for right now while I'm stock and then do the hy-steer, suspension, lockers, and tires all in one shot.
Thanks again 88runner, you've been a big help  :thumbs:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
donkeykong
Start a thread on what it takes to put powersteering on a truck.  I know there are several that have done it on here, and they would be happy to assist you.  My dad did it, I will try and get him to post what he did
Volcom
Quote from: donkeykong on January 20, 2005, 02:02:54 PM
Sounds like a good idea.  yea, I'd like to see what your dad did and how it turned out.  Thanks  :usa:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
MidgetMike
Heres what cross over looks like
Volcom
Yea, that's Hy-steer crossover.  I thought there was such a thing as regular crossover.  I also thought that regular crossover came on the IFS trucks and I could just steal the parts from the frontend and convert over to crossover.  88runner cleared it up for me.  I didn't realize that the IFS crossover had that funky idler arm thing.  I guess I'll just save my money and get hy-steer  :turtle:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Uncle Jesse
ifs trucks, as well as the 2wd trucks, use Paralellogram steering.  The shape of the pitman and idler, center link and an imaginary line between sector shaft in steering box and idler arm shaft make a paralellogram shape.  But you can just call it standard steering.
derek
Quote from: Volcom on January 21, 2005, 02:12:08 PM
regular crossover has the tie rod below the springs instead of above the springs like high steer.
thats the only difference.
derek
derek
here is a pic of regular crossover.
the welded double arm is broken, but you get the idea.
derek
derek
another before the broken arm.  :slap:
derek
Rockcrawlintoy
hahah i have been upside down there before. lol that little place claimns many rigs
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
ezthere
Derek going turtle....That little spot claims many?  Just the same funny.
Chuck
