23 spline all the way
Started by vova, November 06, 2002, 05:51:51 PM
vova
Right now i'm running a 4.3L - R151- dual cases with 4.7 gear in the second case.
What do i need to do to change my second case to 23 spline so i'm 23 all theway through?
Will i need to replace the 4.7's :stopit:
rEdnECkwHeE1eR
#1
Isnt the R151 a 23 spline tranny?
Liquor up front
Poker in the rear
Brandon
#2
yea, you will..
I am 23 all the way but no 4.7's..
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Chewbacca
#3
so if i want to get 4.7 gears and be 23 spline all the way i should order the 23 spline 4.7 gearset for the rear case, and a 23 spline output for the front case?  i'm preparing to put my turbo tranny in and need to rip it apart anyway and put a 23 spline input into the front case anyway...
am i correct??
85 4runner sr5 turbo with some stickers
Chewbacca
#4
anyone?
cruzila
#5
That sounds right. As long as the trans is 23 output and you get the 23 spline coupler for the dual adapter.  :beer:
#6
That's right.
Basically this is how it breaks down:
Transmission > 1st Crawler Input > Crawler Coupler > 2nd T/case Input.
So thats...
23 spline R151F > 23 spline Crawler Input > 23 spline Crawler Coupler > 23 spline Transfercase Input.
If I ever get some $$ and start up a rig, here is what I will do:
Marlin's Heavy Duty L-Series Transmission 21 spline > 4-Speed Transfercase 21 spline Crawler Input > 23 spline Crawler coupler > 23 spline 4.70 transfercase Input.
That would be the strongest setup behind a 21 spline trans.
Vova: How old is your gear set? I think we have a couple of those older gear sets somewhere on a shelf that we would exchange your 21 spline for a 23 spline input. I would have to check with Marlin to see if we have any. I know we have done this in the past for customers at no cost! Just as long as your gear is still in good shape. :)
Regards,
vova
#7
QuoteVova: How old is your gear set? I think we have a couple of those older gear sets somewhere on a shelf that we would exchange your 21 spline for a 23 spline input. I would have to check with Marlin to see if we have any. I know we have done this in the past for customers at no cost! Just as long as your gear is still in good shape. :)
Regards,
My 4.7's are about a year or so old.  So if i trade you the 4.7's, i'll need to buy a 23 spline Crawler Coupler and 23 spline Transfercase Input?
Thanks
Chewbacca
#8
So if I have a 21 spline setup right now then I will need to also get a 23 spline 'coupler' for my actual adapter?
#9
oh whoops.
Yeah, you must get a 23 spline coupler as well. Sorry about that.
I am not sure if we would do a direct swap on your setup. Just give Marlin a call and you guys can get it figured out - !
#10
QuoteIsnt the R151 a 23 spline tranny?
That and the R150F (V6) 5spd trans are the only 23-spline trans.
The differences is that the R151F uses a 4.34:1 First gear as compared to a 3.83:1 First on the R150F and the R150F uses a different rear tail shaft housing that mates to a chain drive transfercase rather than a gear drive case.
FYI, The R transmissions are still used today and hold up exceptionally well behind full size V6 T100s and V6 Tacomas with TRD Superchargers!
