whats difference in 2 pinion rear and 4 pinion rear axle
Started by 80yote, March 30, 2011, 07:19:21 PM
80yote
i have one from 87 turbo thinking about swapping into my 80 even though it is wider
4Runner_kid
Quote from: 80yote on March 30, 2011, 07:19:21 PM
4 Pinion is stronger. Make sure the gear's in the rear end are the same as your's. Good luck!
1992 Toyota 4Runner: Trail Gear Front Bumper, WARN M8000, 1st Gen 4Runner Roll Bar, Back Up Light, K&N Intake, Magna Flow Exhaust, 15x8 Crager Soft 8's, 32x11.50R15 BFG KM2's, JDM Surf Inclinometer, Aisin IFS Hubs.
I believe that the 80 frame is narrower than the 87 so you may have to move the mounts
2manytoys
The diff itself has 4 pinion gears or spider gears instead of two. You can put a 4 pinion diff into either axle housing.
