Are 31" tires bad on 4.10 gears
Started by 19864runner, March 30, 2011, 08:46:59 AM
19864runner
Hi i was wondering if 31" are bad for a 4.10 rear end on a 1986 4runner? By the way hi EVERYONE!! i am new to the rock crawling.
79yota4x
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
19864runner
#2
your rig looks sick man!!
bigarms23
87hillbillyoter
not at all, i know guys running 35s on 4.10s. :welcome: btw
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
Gear Jammin-Dog Chasin-Yota Man
31" tires will rob a bit of your power but no, they aren't bad at all, tons of people run 31's with the stock 4:10's
I ran 33" tires with 4:10's for a year, 4th gear on the highway, but they were still fine, try the 31's.  You can always re-gear down the road if you need to.
1975 FJ-55 Landcruiser: pretty much stock with 31 x9.50x15 TSL's
1992 Extended Cab Pickup: 22r, weber carb, 51" RUF, F-150 rears, Aussie Front, Welded Rear, etc.
Build: http://board.marlincrawler.com/index.php?topic=78730
80yote
 :)im running 4.37's with 33"tires ,but about to swap in r151f tranny i scored out of donor truck replacing L43 4speed hope this helps
80yote
has anyone ever swapped r151f into 80 hilux with 20r
You will have no problem running 31's with 4.10's, speedo will be just a little off.
Quote from: 80yote on March 30, 2011, 03:35:33 PM
I've ran that in my 80 but also swapped in a 22r/20r hybrid while I was at it. Makes a big difference with the 4.37 's in the diffs. You will need to relocate the crossmember FYI.
Jojogreen
You shouldn't have any problems with 31s except for maybe some hitting on the fenders if you don't have a lift. My truck had 31x10.5 and would grind a little when articulated, but a lift took care of that.
yotaneck13
yea 31's will be awsome i have run 33's and 35's on 4:10's just fine you have nothin to worry bout
Daddys Lil Country Girl
#12
I stuffed 33s under my truck when it was stock and I didn't have any problems. Just a lil rubbage
Joey' Wifey & Rylee's Mommy & One On The Way ;)
emsvitil
31s on an 86 truck and 4.10s for decades on SR5 aluminum 15x7 rims.
The 86 4runner has the same fender lines, so you shouldn't hit anything unless you stick the rims out too far.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
