Ok im an idiot
Started by guywithuglyyota, January 18, 2005, 11:17:56 PM
guywithuglyyota
Yeah, now I know why Im a mechanic and not an electrician. I have been hounding different members on this thing, Mostly Kyota, and WT. Anyway I am attempting to install a delco 12si alternator on my 81 truck which originally had an external regulator. Anyway I was ring to bypass the old one, and all i can get is the dash light. No crank, no anyhting, this sucks. Anyway Im taking her to the shop so they can be paid to take over my nightmare. I hate giving up however I need to get this thing out of my driveway and into the hobby shop to install my duel cases and third's etc.
Luke
What are the wiring colors ont he factory plugs?  I have an 83 here I could compare with.  Id be more than happy to help ya figure it out I just need details.
guywithuglyyota
Hey WT, yeah this project is kicking my a** . the three wires that conected to the original alternator ( 81 external regulator) yellow- sense? white with black stripe- ignition and green- indicator lamp.  The 12si has only two connections and the battery post, as im sure you know.  Well I removed the regulator off the fender and I cannot figure out how to wire up everything without having a rats nest of wiring. i have found that the white wire coming out of the original regulator was the return? Hope all this makes sense!  there was also a red wire that was only hot with the ignition on, as well as the green idiot light. I have heard that connecting the #2 connection to the battery is actually not healthy  for the alternator,  will never generate the amps its designed to push out. ANYWAY I hope all this makes sense! I pretty much was underprepared to start cutting wires. Thanks in advance for the help    :beer:
donkeykong
 :conf:  :conf:  :conf:  to many wires...
Brandon
I didn't quite follow but alternators are easy.
Generally 2 wires, an excitor wire that more less turns it on (a powered wire from a + run source), then a wire to your charging system (battery generally). Any other wires are just for your gauges etc but aren't needed. That is assuming internal regulator but external just means you need a few more from your regulator to your alternator ;)
Make sure it works with the stocker then go from there. I'll try to read into what ya got a bit later - back to work :(
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
guywithuglyyota
Thanks brandon, yeah I am a little too inexperienced with electrical, a normal swap I can do, but the external regulaor is kickin. Im an aircraft mechanic and we have specialists in the Air Force that chase wires. plus the instructions I have found on the net have the wrong wire colors. oh well I appreciate the help though! Ill have her towed monday to the shop.
Luke
