The farther forward you move the box, the more you can move your front axle forward, so your tires don't rub in the rear fender well. Try to keep all your steering arms parallel and as high as you can, (or your pitman arm will drag on your spring). The larger tires (37 plus) you will need to cut the Core Support, or go with a lot of lift.
