SPC Mike's 1985 Toyota Pickup Build Up Thread
Started by spc mike, March 11, 2011, 10:15:21 PM
Dingman.
spc mike
Thanks guys. Hopefully i will be getting my head from Putney's via UPS today, if i do i will post some pics. :sly: ....This head took longer to make as well as longer to ship than i expected :thumbdown:
spc mike
Got my Cylinder head With 265 Putney grind cam and new rocker assembly From Putney's Today!
Over sized, Swirl polished Ferrea Stainless Valves...
OEM refurbished rocker assembly with 3 port oil galley shafts....
OEM rocker arms and resurfaced pads...
Dingman.
Nice..  putneys not too far away from me. Seems like all my buddy's with 22re's have a motor from him.
scoutrunner
Looking good, gona have that engine in and running in not time. then time for diff regear.  what are we going to use to hold the diff to get the 150lb torque on the carrier caps?? also have to put some good torque on the pinion.  Marlin recommends the solid spacer for the elocker.  trail time is getting closer!!!
Dingman.
Solid spacers are always a good idea.  If you have a good vice mounted you can hold the differential to torque everything pretty good.
Bigredwelder
I usually use a BIG pair of channelocks with the third in a vice.
Tungsten isn't filler material!  Quit dippin' it!
Some people are like a slinky....not really good for anything, but they sure can make you smile when you shove them down the stairs!
spc mike
Quote from: Dingman. on April 13, 2011, 05:45:41 PM
Thanks, and ya Putney does great work your buddies are probably very happy with their motors.
Quote from: scoutrunner on April 13, 2011, 05:55:57 PM
Thanks Eric...and ya i Should be rolling with steady progress once i get my oil galley plugs for the block tomorrow afternoon. And as far as the diff's go we can fab something up like ZUK has pictured in his write-ups and just bolt it to my work bench in the shop.. should just take a little fab time.
scoutrunner
sounds good, I put my diff on the table, went and got the dial indicator and magnetic base today, it has .012 backlash right now which is too high i think, zuk recommends .007 or .008 in his builds. I need to fab a tool for the side caps to fit the 1/2" ratchet.
scoutrunner
Where's all the progress, Whats taking so long??  You got that motor done yet??  I picked up a press so get those bearings and we can have a diff rebuild day!!  I almost have mine done, gona do one more paint check then I need to fab a tool to torque the carrier bearings. also cant find a in-lb torque wrench.
spc mike
Hey Eric! Been pretty busy with work lately but did manage to get alot done on the motor .... nothing is stopping me from dropping this motor in within a couple days, except my time  available right now. Sounds good on the diffs though. After i drop the motor in i am immediately gonna work on my dual cases so i can put the tranny setup in all at once. then it will be rolling again...then im doing diffs... :crazy: How did the setup on your third go?? Pretty smooth?
Got my twin sticks and speedometer extention cable in today so nothing is stopping me from  finishing up my duals either. Just time and labor :flamer:
scoutrunner
same here..time and money. the diffs going good, I had trouble at first with the pinion shim but sent zuk a message and he said the pinion race may not be in all the way and sure enough thats what it was, fixed that and put back in the bigger shim and the paint came out nice. Yours will go faster now that I know how too do it.  need to make the tool. dont forget to get the solid spacers for the diffs too. see ya sunday maybe? laterz
spc mike
i swear iam making progress... slowly, but till progress. Here's proof..... the motor is ready to drop in, just need one gasket for the exhaust crossover pipe that was NOT included in the ENGN Builder Kit. waiting for it in the mail. after i install the crossover pipe it will drop in! yay!
scoutrunner
Looks very nice mike, did you see I got the trunnion eliminator kit, got the knuckles on.  did you find the pulley for the PS?  Trail seasons getting close.  just need to torque down the diff to get that installed.  glad you had a good bday  catch ya later
awhotrods
spc mike
Thanks guys! ...and Eric, ya i saw you got that kit, is it smoother than the bearings? and never found the accessories pulley, but i can get that later. still need to get that t-case mount from you too cause i am gonna be tackling the dual cases next  :nerv:
scoutrunner
Zs Confederate Toy
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
SamuelEngelking
84 Toyota Ext, 5.29's Locked Up, 4.7's, 37's KM2, 17" KMC Wheels,
Hydro assist, Propane, Headers, Body Armor, Some Bump In The Trunk..
spc mike
Thanks guys! Iam gonna post more pictures tomorrow. seeya :burnout:
scoutrunner
spc mike
...sorry  :sad2: cant find my camera. ahhhhh :shudder:. But I got the motor in and got all the vacuum lines, gas lines and electrical all plugged in. now just need a little time start tearing into the transfer cases.  :crossed:
scoutrunner
your getting close.  I got my diff installed and bought my taco rotors today, gonna turn the hubs down to fit. getting closer!!  mountain toppers has a run the 14th was thinking on going up for the day!!
spc mike
where is the run to?? Do you plan on putting in the axle this season or next?
spc mike
got a few random pictures of the shiney motor in its home...
Motor is in so i started the process of putting in my 4.70's and dual transfer case set-up together. IF ANYBODY HAS ANY LITTLE TIPS OR TRICKS FEEL FREE TO CHIME IN.... Here is a few pics
Forward Transfer case off of the G52
1 forward shift t-case (crawl box) and 1 top shift t-case(rear case to put 4.70's and twin sticks) on the bench ready to dissect....
Dingman.
when we built my buddys dual ultimates, we just used the instructions it looks like u printed out and it was pretty straight forward
Peterbuilt84
Make sure to take lots of pics of the install  :greengrin: I'm going to be running a very similar setup, so I'm going to be watching this one.
Nice build btw :smokin:
Dingman.
I have heard people complaining about something just make sure if theres an area for a snap ring you don't forget any.
scoutrunner
lookin good mike. when you done with the cherry picker just let me know when you want to take it back to my dads.  that run is somewhere below shaverlake. not sure exactly, you eant be ready yet.  I want to put it in yesterday but just need to wach the funds. still looking for things little by little. axle is almost complete. next is to weld on spring hangers and build some RUF springs for the front and get some f150 springs for the rear.  I think I am going to wait till next season to do the SAS so i can get another Elocker.
wakkjobb
That engine would look better with my header on it...  :eyebrow: and your new HAC will be sent out tomorrow; worked too late to get to the post office today.
>>Dan
