Rims. 15 x 8 's or 15 x 10's.
Started by Motormouth13, March 09, 2011, 09:18:11 PM
Motormouth13
 Is there any advantage to 15 x 10 over 15 x 8 or vise versa?
minicrawlin
depending on your tire size/tire width the smaller or wider rim will work better to seat the bead and keep it from popping. i run 36/12.50 R15 on 15x8 rims and have yet to blow a bead, sometimes running at 0 psi (valve stem popped out ha ha). I believe thats the advantage. not sure of any others.
the rocks Rock in South D SON!
79yota4x
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
H8PVMNT
I preffer 15x8s for 12.50 tires.  They stay on the rims really well ar low tire pleasure...
– Steve McQueen
<MIKE>
same as mentioned. I run 38.5/14.5/15 TSL's and i use a 10" rim because it helps keep my bead on when i'm @ real low psi. I've gone down to 1-2 psi without losing a bead. Just depends on what size tires you plan to run.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
Gear Jammin-Dog Chasin-Yota Man
15x8 is a good all around size rim
unless you are runnin wider than 12.50 or want your tires to mount up nice and wide, I like the 15x8
You can get more side wall bulge with the 8" rim and 12.50 tires, depending on if the tire runs wide or whatever
1975 FJ-55 Landcruiser: pretty much stock with 31 x9.50x15 TSL's
1992 Extended Cab Pickup: 22r, weber carb, 51" RUF, F-150 rears, Aussie Front, Welded Rear, etc.
Build: http://board.marlincrawler.com/index.php?topic=78730
Motormouth13
Alum are lighter, prettier, don't rust.  But they can break, bend, crack etc.
Steel are tougher by far, but can rust, heavier, etc.
I ran both.  Right now I have steel.  Just depends what you want and how hard you are on stuff....
minicrawlin
cheap alum's will but if you go bad ass like KMC alum beadlock style they'll hold up to anythin and some compared to steel. but unless your gonna do some desert racing i'd rock steel. thats what my toy has and although i've bent em before they hold up great like Hound riggin Toyota's talking about. much cheaper also! What are your applications on this rig?
H8PVMNT
Both work well and there are advantages either way.  It all comes down to how much you want to spend...
– Steve McQueen
Personally I have never had a problem with alum wheels holding up, nor have I had a problem with steel wheels, and I'm kinda hard on stuff :yikes:
As long as your not jumping the thing I think you will be fine with either wheel durability wise....
daniresch
15x8 unless your tires are wider than 13.5
alloy wheels because they are lighter and no rust
Onefryday
I have 31x1O.5x15 should I get 15x8 or do y'all think I'm ok?
Muddytazz
15x8s by far
My old rig I used to run 14.5 wide rims on 15x8s and run 12psi on the street and 1psi  while wheeling and never popped a bead.
The 8" IMO are the best bead holding rims.
Build it right or get off the trail
daniresch
Quote from: Onefryday on June 22, 2011, 05:20:26 PM
15x8 is on the wide side for a 31/10.5/15. will it work? yes.
I would personally run a 15x7.
Nimyad
A good rule of thumb is run a rim about 4 in shinnied then your tire. And I personally like alum because from what I've found it holds the bead better
daniresch
Quote from: nimyad on June 29, 2011, 02:29:31 PM
That completely depends on the design of the barrel.
Monster Yota
I run Aluminum 15x10s on 38.5x14.5.15 Sxs at 2-3psi all the time and haven't had a problem so far...
MARLIN 4 PRESIDENT!
