Diff armor
Started by birfection, March 07, 2011, 03:44:07 PM
birfection
Just bought some diff armor for my rear axle. do i need to drain the oil from the diff before i weld the armor on?(I just filled the stinkin thing!)
TITAN CRUSHER      http://www.youtube.com/watch?v=v6qnDVgWBSA
1980 Pickup: 22RE (bored 20 over, OS Valves, 261 cam, ported and polished intake/exhaust, Pacesetter long-tube header), L52 5 Speed, 6 leaf RUF, 63" Chevies, Hi-steer, 35 x 12.5 Maxxis Creepy Crawlers, Dual 2.28 cases, Detroit Front, Welded Rear, 5.29s
BikerTrash
I might be wrong, but I would think leaving the oil in it would be safer: if it is empty, the heat you put into the metal would just have to heat up a thin film of oil to get it to start smoking and ignight. If it is full of oil, the oil should act as a heatsink. atleast thats how I think it would work.
There is a fine line between clever and stupid, I just wish I knew when I crossed it.
84 4runner
02 Suzuki V-Strom
95 Honda 1100C1
06 Ram 2500 4x4
(please note, listed in order of preference)
Goldrush
idk. u could be right, you could be wrong. what i would do it drain the oil into a clean bucket, weld and then use that oil over again if you can.. :twocents:
junya92toy
Weld it with the oil in it. Heat sink and it wont catch on fire. Youre truck wont burn to the ground, if any does "flare up" it will use what little 02 that is in there and go out
yoshaleng
I welded mine full of oil and had no problems.
Burl
Me too front and rear.  No problems.
79yota4x
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
bleakhorizon
when i welded my front armor on, my axle was out, empty and clean.... STILL smoked and sizzled like a b*std......  so i would prob leave it full also...
Those are some huge welds!
Tillamook, OR
1983 toylet
I welded mine on with oil as well and had no problems..
1983 Toyota/Chevy Conversion 35" BFG MT
2005 Tacoma 3" suspension lift 285/75/16 ProComp MTs
