putting a 90s rear end in first gen
Started by 79yota4x, February 28, 2011, 10:06:06 AM
79yota4x
does it bolt right up? is it fairly quick to do :hammer:
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
superyota
it will bolt right up.  you will need the longer hardline for the brakes though.  and make sure its not a 4runner rear end.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
yoshaleng
Quoteit will bolt right up.  you will need the longer hardline for the brakes though.  and make sure its not a 4runner rear end.
X3
good chance of loosing your e-brake if it's a runner rear end.
:welcome: II  :turtle:
Sparkplug
NO, you will need a u bolt flip kit, as the old axles are thinner tube, and your orig u bolts and plate WILL NOT fit around it correctly. Your e brake cables will not be long enough either, but you can make extensions easy/
fade
dont need a flip kit, unless you get the stock u bolts with the axle. if get u bolts and plates from a 4x4 ranger at the junkyard its a cheap flip kit, if your running chev or ford springs get the u bolts and plates from one of them at the junkyard. cheap flip kits, sparkplug told me about it.
86 mini truck 18" rays
09 highlander
70 suburban
79yota4x
Cool thanks I got a complete one sitting behind shop  I want to swap cuz it's wider
fade
how are you going to widen the front, spacers or ifs hubs and fj brake swap?
09 highlander
70 suburban
79yota4x
I got spacers or Ifs hubs never heard of that which ever one is easier
79yota4x
