Since you have a 4runner, then swapping out fuel pumps is cake walk. Since you don't have to drop the tank.
put a jumper between B+ and FP, then you can eliminate the pump if it stays running.
Take a 12mm wrench, after trying to start it and it dies, turn the key off. To check if there is enough fuel pressure in the fuel rail, loosen the small banjo fuel fitting on the cold-start injector mid-top side of the upper manifold next to the valve cover.If gas sprays all over you have enough fuel pressure.
iac idle air control
the plastic srew on the top be careful thothey break easily
Started by krawler76 Tow Rig and Trailers
Started by Slolyfe Toyota Pickup/4Runner Tech 1979-95
Started by 83yota Engine
Started by REG535 Toyota Pickup/4Runner Tech 1979-95
Started by Toyospearo Toyota Pickup/4Runner Tech 1979-95
