Author Topic: HELP stock toyota carb wont run  (Read 1239 times)
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« on: Feb 18, 2011, 01:15:40 PM »
I have a stock toyota carb that i am putting on my 22r truck  it ran previously on another carb
I have all of the vac. lines blocked off except for the two that go to the dizzy  if I press the gas 1 time to the floor to set the high idle  it wont run. if i spray starting fluid down the barrel of the carb and set the high idle  it will run until the starting fluid runs out. if I press the accelerator pedal about 10 or 15 times over and over it will fire over and run for maybe a second or two then die. WHAT AM I DOING WRONG ??? :turtle: :turtle: :turtle:
[img]http://bo
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
Re: HELP stock toyota carb wont run
« Reply #1 on: Feb 18, 2011, 03:59:48 PM »
Either a stuck or incorrect flow level.
HULK
  • Turtle Points: 306
  • Male Posts: 164
  • Member since Dec '10
« Reply #2 on: Feb 20, 2011, 07:05:14 PM »
On my pop's old yoda, the float arm was not adjusted right.  If the carb aint new, check the float arm.  I had the same problem with his, and that's all it was.  Just something that may help.  Good Luck.
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #3 on: Feb 21, 2011, 10:02:02 PM »
I'd say that your not getting enuff gas into the carb. look in the window, can ya see any?
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #4 on: Feb 22, 2011, 09:54:31 AM »
ok I found out that I had a MASSIVE vac. leak I plugged it off and it runs IT DON'T IDLE RIGHT BUT I CAN FIX THAT
for 45 buck the Toyota Dealership is going to adjust it right  for me  so then I will know ITS DONE RIGHT by there books and ears
[img]http://bo
Last post Apr 01, 2005, 11:53:17 PM
by PinkToyota
Last post Mar 06, 2008, 08:07:42 PM
by kneedownnate
Last post Mar 06, 2008, 07:52:13 PM
by jimbo74
Last post May 23, 2008, 01:16:27 AM
by Bazzi
Last post Dec 08, 2008, 11:46:01 AM
by AR80Toy
