L50/L52 lube?
Started by kyle_22r, January 16, 2005, 09:37:05 AM
kyle_22r
how much gear oil does one of these transmissions take and what kind do you recommend i should use?  i'm thinking of going with a synthetic lube to prolong its life
75w90 or 80w90 is what the manual recommends, but I'm missing the section that says how much,    Nate
KYOTA
L52
1.9 qts.  API GL-4 or GL-5  SAE 80W/90
Skinny_Pedal
i always just fill it till it comes to the fill plug
Im an OG
kyle_22r
i got some GL4 85w90 oil($5 a quart sheesh), took a bit over 2qts to fill up.  i've heard to stay away from true GL5 in toy trannies as it makes them hard to shift due to it being too slick on the synchros...i didn't have any qualms about putting it in my t-case though, cheaper too!
KYOTA
Quote from: kyle_22r on January 17, 2005, 07:50:18 PM
($5 a quart sheesh)
The exact reason I buy it in 5 gal. buckets (about $35) and use a pump, plus with the pump its easier and faster to fill diffs, trannys and t cases.
kyle_22r
i bought a pump but it wouldn't work right with the mini sta-lube jugs.  i had to end up holding on to both the pump, jug and top hose, since it wouldn't screw to the jug.  made a huge mess, and found out what it's like to take a bath in gear oil :nonono: but it eventually did the trick
KYOTA
I meant a bucket pump like this
kyle_22r
yeah, should've borrowed one from work :hammer:
fuglytruck
i have a L52     and run 80w90     and also fill it till it pours that nasty ass smelly shity fluid all over  then its time to cap her off.      funny thread
i just cut a guys 4x4 in half and he didnt even put up a fight.
Skinny_Pedal
Quote from: kyle_22r on January 17, 2005, 10:31:13 PM
i had the ame problem as u....i smelled like 90w for 3days. next time im buying that 5gallon bucket
Im an OG
fuglytruck
lol  i have u all beat on the smelling of gear oil... i had a oil pan on a v16 motor at work crack and depresureize all over us.    im mean really all over us.    we were covered from head to toe... try cleaning that stuff out of ur hair sometime...
