Author Topic: axle truss  (Read 6944 times)
hi on lux
  • Male Posts: 208
  • Member since Jul '06
axle truss
« on: Feb 17, 2011, 07:42:37 AM »
when welding a truss on axle housing, does it have to be fully welded, sealing the cavity? or stitch welding only?
Burl
  • Turtle Points: 271
  • Male Posts: 389
  • Member since Jan '07
  • Wannabe Smokejumper
Re: axle truss
« Reply #1 on: Feb 17, 2011, 02:45:55 PM »
Don't do a full length weld, you will end up warping the axle most likely.  Tack weld it really good on all the major corners, then stitch weld on opposite alternating sides and location to prevent overheating and warpage.  After the stitch welds have sufficently cooled you can go back through and re-stitch the unwelded portions for a fully sealed truss.  I personally left mine stitch welded.  :twocents: :flamer:
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: axle truss
« Reply #2 on: Feb 17, 2011, 03:27:03 PM »
The less welding you have to do, the better off you are. Try to weld all the spots where there are no gaps, metal to metal. Like a top-notch fabricator that I know (he also welds pipelines) told me "I have seen more Toyota housings bent from people welding parts on them to make them stronger so they will not bend" IMO all you need are the ball gussets, because that is where they bend most of the time.
yjay
  • Male Posts: 555
  • Member since Feb '09
  • SFA Station Wagon
Re: axle truss
« Reply #3 on: Feb 17, 2011, 06:25:52 PM »
I agree with OOPS. All the stress is outside the leaf springs. I think a top truss is in the least stressed part of the axle. I warped one myself and only did small stitches at 1" of weld in every 3". Wrecked it. Pretty sweet when you are all done with your rebuilt axle and can't get your birfs in. I won't be doing a truss on the '85 axle I'm currently building. Just cut and turn, diff armor, and lower ball gussets.
« Last Edit: Feb 17, 2011, 06:32:26 PM by yjay »
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
hi on lux [OP]
  • Male Posts: 208
Re: axle truss
« Reply #4 on: Feb 17, 2011, 09:30:56 PM »
I just didn't want to be overzealous, I took advantage of the time that the front was still not yet been refreshed and off the truck yet, we stitch-welded the upper truss, upper and lower ball gusset before dis-assembly... now that it is almost
"refreshed" but still not mounted on, diff armor will next be welded.... stitch again too? In your opinion.....
@ yjay.... cut and turn? for the knuckle ball?
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
Re: axle truss
« Reply #5 on: Feb 17, 2011, 09:36:56 PM »
you coulda done a tube truss so then you really wouldn't have had enough heat when welding to warp the axle.
diff armor doesn't really matter cause it's not gunna warp anything, but do leave a place unwelded so water can get out
yjay
  • Male Posts: 555
  • SFA Station Wagon
Re: axle truss
« Reply #6 on: Feb 18, 2011, 06:00:38 AM »
Yup. To add caster angle and eliminate any chance of death wobble and improve road manners as well as to set pinion angle.
22re Daily Driver
greg_k113
  • Turtle Points: -49
  • Male Posts: 224
  • Member since Feb '10
Re: axle truss
« Reply #7 on: Feb 18, 2011, 06:13:01 PM »
Can you use a stick welder or should you use a mig?
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
  • Member since Nov '08
    • oppiz.net
Re: axle truss
« Reply #8 on: Feb 18, 2011, 06:36:10 PM »
Doesn't really matter. I have fully welded them, just do small 1" 1/2" welds over time. flip side to side and let it cool between each weld.
If you see it, its for sale.
Outsane
  • Male Posts: 51
  • Member since Nov '10
Re: axle truss
« Reply #9 on: Feb 22, 2011, 10:17:30 AM »
Can you leave the the axles/diff in or do they need to be taken out?
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Re: axle truss
« Reply #10 on: Feb 22, 2011, 11:40:43 AM »
leave them in. no need to remove them.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Last post Nov 26, 2004, 04:36:37 PM
by jvministries
Last post Jul 26, 2007, 06:13:22 PM
by Saber
Last post Oct 20, 2008, 09:31:43 PM
by tech201
Last post Sep 30, 2012, 10:18:18 PM
by IronClad
Last post Aug 31, 2014, 12:14:00 PM
by locktup
