Engine differences???
Started by toyhunter, January 15, 2005, 08:20:46 PM
toyhunter
 Is there really a difference in engines between a 85 22re and a 94 pickup with a 22re. What differences are there? Is one better then other? :headscratch:  :psss:
Everyone starts off in life crawling but lots of us grow up and still are crawling around everywhere
kyle_22r
the long blocks are the same, i think in '92 or so they changed the design of the intake manifold.
wiring changed periodically though.
Marlin
There is a major differance :_order:
The '85 uses an resisitor for the 9 volt style injectors, an angled throttle body, and a slower, one oxygen sensor computer.
The '89-'95 trucks use two 02 sensors, 14 style volt injectors, straight throttle body with a redesigned air intake, and a faster computer.
mplatzer
wow marlin couldnt have said it better myself.
HAMMERS THE BEST TRAILS IN THE WORLD
FATB0Y
Quote from: toyhunter on January 15, 2005, 08:20:46 PM
This should tell you any thing you need 2 know about 22RE  http://www.toysport.com/Technical%20Information/22r_tech_notes.htm
lilbuddy
Quote from: 03HDFATBOY on January 18, 2005, 12:26:41 PM
Yes take a look at that website. That has some good quality information on the 20R/22R/22RE/22RTE motors...
Chris
RIP Kyota.... you are the man
GET IT!!!
FATB0Y
