15x12 fitment?
Started by ratzila, January 14, 2005, 06:17:12 AM
ratzila
I am looking at some American Racing Outlaws II 15x12's. They were on a 90 suburban. Will they fit on a 85 toyota. I know the bolt pattern is the same but this wheel has 4" bs. Will that interfere with steering parts? Thanks, David
Fireimp141
usually you try and get a 3.5 or lower bs... i dont know if the 4 will interfere, i have an 86 4runner with 3.75 bs and they are just fine.  :twocents:
ratzila
So if they don't fit I could use spacers. I've heard its bad to use them but some people use them to widen the front end. Thanks for the reply.
ratzila
I just found out they have a 3.75 bs so I will be buying them.
86yota
If there 3.75 thats good.  Just for future referance 4" hits the tie rod end on a 79-85 solid axle, unless your running IFS hubs.
Fireimp141
Which you should be doing anyways :thumbs: and also wheel spacers are good, except for they have the tendency to come loose and possibly loose a wheel :-\\ depends on ure amount of city driving also.
ratzila
For now Ill try to get by without using the spacers if the wheels clear ok. But whenever I swap to the wider rear axle I'll find some ifs hubs. Thanks for the info :thumbs:
