Trailer wheel torque...
Started by emsvitil, February 04, 2011, 08:46:43 PM
emsvitil
Simple question, can't find an answer.
How tight do you torque the lug nuts on a trailer?
15x5 steel wheels
205/75 15 tires
5x5 bolt pattern
They're currently at 75.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Quote from: emsvitil on February 04, 2011, 08:46:43 PM
15x5 steel wheels
205/75 15 tires
5x5 bolt pattern
should be like 86-90
junya92toy
Id get the size of the lug itself and find a chart for what size diameter that lug can handle
emsvitil
Quote from: junya92toy on February 04, 2011, 09:32:20 PM
But it's dark outside
:yupyup:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
1/2" studs
(now I'm warming up next to the furnace)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
90.  You're welcome.  And for the record, lots of trailer lugs actually have the torque stamped on them  ;0
brainlessfool
I just run them down till one brakes and then back the othrs off just a bit :boozer:
You joke, but some people seriously have no idea that there's such a thing as over-torquing  :shudder:  Some are very aware and watch to make sure their vehicle is torqued, then ask just to be sure, but far too many are oblivious and just tighten them as hard as they can.  They're often the same folks who run 65 psi in a tire with a 35 psi max  :ack:
emsvitil
All torqued to 90.
And 45 psi (load C, 50psi)   I don't like running at max psi, plus I was only at about 4600lbs total weight out of 7000...
Thanks.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Run em at 50.   Trailer tires are designed to be run at max psi, and can actually overheat and begin coming apart inside if not run at max.
