Extended Brake lines
Started by greg_k113, January 27, 2011, 11:01:08 AM
greg_k113
I was just wondering if anyone knew of any budget brake line ideas you could buy (maybe for another vehicle) that are longer but would work on a Toyoya truck I need mainly the rear rubber line for now but info on the front would be good too since a SAS is in the future for my truck. Parts # or make and model would be appreciated. Thanks in advance. (I put F-150 springs in the rear so I need a longer rear brake line.)
GNasty 82
Most just replace the stock flexy lines with extended length braided lines such as what Marlin and crew sell.
http://www.marlincrawler.com/brake/brake-line/extended-brake-line-kit-hilux
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
Peterbuilt84
1990-1996 Nissan 300zx brakelines napa part number 38688 work.
From http://www.pirate4x4.com/forum/showthread.php?t=775780
Rocksnail
In the fear i just hooked two rear lines  together. works well
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
IronClad
can use the rear line trick up front too
Annihilation  Fabrication
Do you need a Hammer?
4RunnerChevy
Quote from: IronClad on January 27, 2011, 07:10:00 PM
x2, before I bought overpriced lines, I ran these on all three, and still carry one as a spare.
greg_k113
steveco.
www.sweetperformance.com  $30 for extended brake lines. great service.
located in Placentia, CA
Let's put a smile on that face!
Jojogreen
I went to riebes and had them pull up brake lines that were the length I wanted then found the ones with the right fittings on both ends. Took me 3 tries and they didn't have one in stock, but ended up working out. Go braided by the way.
