Yes it would. I've done it before using a push button switch, turn your ignition on...push button start. Easy to hide too!
"make sure you use a push button as suggested so the starter does stay engaed longer than needed".
He probably thought you were going have it hooked up to your starter...therefore the starter would stay engaged until switched to "OFF" position.
"Interrupting the coil, fuel, ignition is a bad idea. Stick with the starter. dangerous to have component failure at 55 and lose your brakes and steering. Happened to a friend (relay crapped out) and he took out a family because he couldnt stop in time. Luckily nobody was seriously hurt.There is a reason that you can not but an alarm anymore with IGNITION KILL. Its all starter kill now."
Started by awhotrods Project Research and Build-Ups
Started by red Toyota Pickup/4Runner Tech 1979-95
Started by Steve_925 Engine
Started by yjay Toyota Pickup/4Runner Tech 1979-95
Started by krogen223v Newbie Questions
