How would you make a single tow bar? I always thought the towed vehicle had to have two mounting points so it wouldn't swing around.
How would it be jointed?
I want to get some pointers on building a flat tow bar. I could be flat towing my Yota 600 miles. There are hills for the first 100 miles then the rest is flat. I am wondering if I can drill some 3/4" holes (pictures show location) in my 1/4" plate bumper for mounts. I would put a 3/4" grade 8 bolt through these holes to bolt up 1/4" plate that will attached to the flat tow bar. Or I could drill 1" holes and sleeve the holes with a tube about 1.5" long, and still run 3/4" bolts. Any tips? Ideas? Concerns?
snowtoy please don't offer any more "advice"
Simply telling me to shut-up doesn't bestow upon me or any other member on this board the wealth of knowledge regarding tow bar/trailer tongue design and function that you must have, and is a reply more suited for Pirate than this Marlin, or is Pirate something this forum is striving to become. So Omnipotent one, since you claim to have all the answers, please explain what was wrong with the advice I have given? If you read my post I stated the best place to attach a tow bar would be where the the bumper tabs attached to the frame in the first picture. There is nothing wrong with this point, A buddy flat towed his rig from that same point through mountain passes and winding roads for several years, all w/o issue. No bending of the bars, no issue with the flat towed vehicle drifting either, even on windy passes or winding mountains at highway speed.
If you are referring to the single bar idea, JRock asked how it could be done using a single tow bar rather than a triangulated one. My response was that it might be doable seeing how a "T" tongue is used on trailers that don't have a lot of tongue weight. However I stated it would have to be something that would need to be looked into, since I was unsure of what type of lateral forces might be applied to a single bar, what size the bar would have to be to counter those lateral forces, and tht it all depended on if that section under the bumper was in fact designed to be a drop hitch receiver. If it is strong enough to be used as a recovery point, it should be strong enough to flat tow the truck from.
As to the need of the tow bar to pivot up and down, is there any reason for it to do so other than being able to lower it onto the tow vehicle?
Does it need to move any more than the 45* of travel that a standard ball and hitch have in order for the flat tow to work, if the bar is at the same level as the ball on the tow vehicle?
Would it not be similar to a tandem axle trailer, or does a tandem axle trailer pivot enough at the wheels to not need a tongue with vertical pivots in order to cycle its suspension?
These were questions I was asking, something you didn't bother taking the time to answer, if you actually do know the answers.If my advice is indeed worthless, yours isn't any better, you gave no practical reason as to why you feel moving the ends as far as possible out on a vehicle would be benefitial, other than that your friend's had his fold up. You didn't even bother to explain how the bars folded up, or why moving them 2" out on each side would have prevented them from folding up under the same conditions?
From what I have gathered, you want the two mounts (towed vehicle) to be 24" apart. The body mounts are 26" ish apart. So, what if I sandwiched an piece of 90* metal under the body mount. Then bolt a tow bar to that.
thats the kind my buddy used that folded up.it was a Reese brand but i think it was just cheaply made.
Started by AJ Project Research and Build-Ups
Started by jafish Toyota Pickup/4Runner Tech 1979-95
Started by toys4life Parts For Sale
Started by vegeloon New Member Check-In!
Started by watb21 Axle/Differential/Steering
