Author Topic: instead of fuel pressure regulator?  (Read 3930 times)
40mikemike
  • Turtle Points: -2
  • Member since Nov '10
« on: Dec 31, 2010, 10:56:05 PM »
Howdy all, instead of running a fuel pressure regulator anybody try to "neck" down (pun intended) the fuel line I have a couple extra line to line butt connectors, thinking of going down in 1/8" increments from the pump to the carb?  (22R desmogged weber 32/36)
Might save me $20 anyone think it'll work, done it???
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
Re: instead of fuel pressure regulator?
« Reply #1 on: Dec 31, 2010, 11:19:55 PM »
No.
You'll restrict flow and pressure.
If you lower the pressure enough at idle so that you won't flood out the carb, you'll never get enough fuel at WOT.
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #2 on: Dec 31, 2010, 11:20:13 PM »
nope. will not lower presser at idle at all and will not let enuff fuel though at high speed.
40mikemike [OP]
  • Turtle Points: -2
« Reply #3 on: Jan 01, 2011, 12:50:14 AM »
well that's solved thanks,
what fuel pressure reg do you folks recommend?
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: Jan 01, 2011, 05:05:38 PM »
Necking something down will increase the pressure, lessen the volume, think fire nozzle.
4RunnerChevy
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #5 on: Jan 01, 2011, 11:19:08 PM »
x2
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
« Reply #6 on: Jan 01, 2011, 11:28:02 PM »
you can get a fuel pressure regulator for around $20....
40mikemike [OP]
  • Turtle Points: -2
« Reply #7 on: Jan 02, 2011, 09:06:38 PM »
"well that's solved, thanks,
what fuel pressure reg do you folks recommend"  post #4
« Last Edit: Jan 02, 2011, 09:21:17 PM by 40mikemike »
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
40mikemike [OP]
  • Turtle Points: -2
« Reply #9 on: Jan 03, 2011, 11:16:51 PM »
Thanks all!
 going to get the redline 31800.063 its about $60.00 but I'm one to return even the $1.00 bad bolts I occasionally get at lowes
going to attempt to tune my weber per online intructions then tweek the redline and violla
call this thread dead.
motormouth559
  • Male Posts: 917
  • Member since Oct '07
« Reply #10 on: Jan 03, 2011, 11:24:58 PM »
I got a holly pressure regulator wen running the 32/36 from my local Orileys worked great only cost 20-30 bucks
Last post Nov 05, 2005, 06:33:10 PM
by Duffil
Last post Dec 22, 2006, 10:39:39 AM
by TRHS1980
Last post May 07, 2009, 01:42:08 PM
by Duffil
Last post Jun 11, 2011, 03:04:07 PM
by Fiercefirstgen559
Last post Aug 13, 2013, 06:07:22 PM
by <3 Low range
