Window help
Started by toyhunter, January 08, 2005, 12:08:51 PM
toyhunter
Hi I want to install my back side windows the ones behind the door on my cruiser and dont know how to get them in do you have suggestions or certain ways to do it????? :dunno:  :dunno:
Everyone starts off in life crawling but lots of us grow up and still are crawling around everywhere
billy hill
I've done windshields before. And just took the rubber gasket, set it out in the sun ( or heated it up). Put it around the windshield. Then took a long enough piece of string, and stuffed it in the groove where rubber seals on the windshield opening. Set the bottom in place. Then pulled on the string while someone was pushing on the window. When you pull on the string, It forces the rubber to set in place. If you do this, just make sure that you lube up the string first. It makes things a whole lot easier. At least on VW's it does...
official mall crawlin pavment pounder #1
Snowtoy
Works the same way on Toyota truck windows, should work on the Cruiser.  Any type of lube will work, soap, hand lotion etc.  I find sticking the rope in a heavy soapy water solution works good as well and it is easier to clean up.
reklund5
I always use silicone spray lube- works great and really slippery!
Ryan
toyhunter
I put em in today with just dish soap water and a string and it worked fine
