Author Topic: Air shock psi?  (Read 2205 times)
woodfella
  • Member since Nov '09
Air shock psi?
« on: Dec 24, 2010, 09:42:07 PM »
Switched over to 2.5x16 from 2.0x14. With the 2.0's I was running 340lbs and now with the 2.5's I only need 80. Does that seem strange to anyone else?? What are you guys running for preassure in you 2.5's?
thanks
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
Re: Air shock psi?
« Reply #1 on: Dec 24, 2010, 09:51:41 PM »
I use to run 275 with fox 2.0s.... makes sense that the 2.5s would take less psi cuz they have more surface area.
91 Toyota High pinions f&r.
Jeepcrasher
  • Turtle Points: -1
  • Male Posts: 24
  • Member since Dec '10
Re: Air shock psi?
« Reply #2 on: Jan 25, 2011, 03:20:36 AM »
Yes it takes less pressure in 2.5's due to increase in surface area of piston
Example:
2.0 piston surface area is 3.14sq-in multiplied by 200psi=628.3185 lbs of force
OR
2.5 area is 4.9sq-in multiplied by 128 psi= 628.3185 lbs of force
So less air pressure but applied over bigger area is the same force
Later
Crashed
I was so scared I think a little bit of pee came out!
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
Re: Air shock psi?
« Reply #3 on: Feb 03, 2011, 09:26:36 AM »
Just remember the air pressure isn't the spring rate, its only the ride height. The oil volume controls your spring rate.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
Re: Air shock psi?
« Reply #4 on: Feb 03, 2011, 01:24:52 PM »
Aren't you supose to use nitrogen? and not air?
If you see it, its for sale.
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
Re: Air shock psi?
« Reply #5 on: Feb 03, 2011, 01:52:09 PM »
Yes
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
Re: Air shock psi?
« Reply #6 on: Feb 04, 2011, 10:28:48 PM »
exactly!! with air your only adjusting the ride height, so if its at the ride height you want but is too soft, then put some extra oil in them.
UA 342
STEAMFITTERS
woodfella [OP]
Re: Air shock psi?
« Reply #7 on: Feb 17, 2011, 08:04:41 PM »
Example:
WHOA! Easy there buddy:)
I already knew all the other stuff about ride ht (thanks for the responses) just thought that was a crazy drop in psi from 2.0's to 2.5's
OR
Later
Crashed
WHOA BRAIN? WOW I feel stupider now. Thanks for all the replies, I am aware of the ride ht and the fact that its not "air" but thanks for all the replies. I guess I needed to put more emphasis on the fact that I was dropping soooo much preasure going from 2.0's to 2.5's. Just seemed excessive...
Last post Jul 13, 2009, 09:14:08 PM
by REG535
Last post Jul 02, 2013, 01:03:42 AM
by Saved-wheeler
Last post Jul 21, 2013, 08:00:04 AM
by E YOTA
Last post Jan 14, 2014, 10:31:05 AM
by twistedtoy92
Last post Apr 10, 2016, 01:36:33 AM
by kneedownnate
