triple stick? bench seat?
Started by red450r, December 16, 2010, 05:31:41 PM
red450r
im looking to put twin cases in my truck, i know very little about them and want to keep my bench seat (lil one on the way), would a triple stick allow me to do that, and what adapter do i need? its a 94 with a 22re and i know that my donor case is a 21 spline :headscratch:
yota4x4sc
u just need a 21 spline adaptor... and i keep my factory bench seat in..my dual shifter cleared nicely
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
yota4x4sc
red450r
what did you do for the x member and i seen on marlin that it like 3 different adapters
yota4x4sc
i got the all pro skidplate w/ driveline ebrake..super nice setup..... but u just proly want the regular adaptor..the other ones billet and ones rotated 10 degrees and one is normal
red450r
Snowtoy
W/a bench seat you might check out this set-up http://www.pirate4x4.com/forum/showthread.php?t=916481, the 3 shifters are located on the front case, w/levers that operate the 4H and 4L functions of the second case.
I modified the front shifter, so it could be located next to the rear case case shifter, for a little cleaner look.
The shifter only has to move forward and back, not to the right and as well, so I don't know how that extension would effect the amount of space the shifter would have to move to engage 4L, 4H wouldn't be a problem.  A short through shifter kit on the second case might reduce the movement enough to not have the shifter end up in a position that gets in the way.
fade
86 mini truck 18" rays
09 highlander
70 suburban
Tofudude
Good gosh snowtoy...your interior is beautiful  :love:
Yota Rolla
Quote from: fade on December 17, 2010, 12:41:03 AM
Nice integra seats.
:haha: :idiot: not integra seats bud. .
heres a couple pics of my setup nowhere close to finished still need to do some cutting on the floor but as you can see the twin sticks(front range) clear the 60/40 split bench nicely. .seats are out of a 2000 Tacoma and there in my 1st gen pickup with mounts i made
82 locked,geared,cased,caged daily
Snowtoy
Nice integra seats.
The seats are from a '94 Supra, with the exception of raising the rear mounts 1.5"(to match the oem slope of the truck seats), they bolt right in.
Quote from: Tofudude on December 17, 2010, 01:46:27 PM
You should have seen it when I drug it home.  Before I got it, it had spent the last 12yrs of its life as a winery truck, and it looked like the PO hauled more garbage, manure, and dirt inside the cab then the bed.  It took a good 12 hours of cleaning to get the smell out, fortunately everything but the seats were re-usable.
