my toyota 4wd a-arm buggy...
Started by mosebilt, December 12, 2010, 01:20:34 PM
mosebilt
 :beer:
Sparkplug
Saw this on pirate too,  :bowdown: :bowdown: :bowdown: :yikes: :yikes: :yikes:  :beerchug: :beerchug: :beerchug: sick as hell man
RABIDYOTA
some one is thinking outside the box    are those both ifs diffs?  what kind of travel u looking at geting
Sparkplug
just curios, but it looks like trans points opposite way, does thi reverse your shift pattern, ie rev being where 1st norm is? Also, do you run a normal drivetrain, just flipped around pretty much, with front output going to rear axle? offset?
:smack: looks auto, but still wonderin about if u just flipped drivetrain and have front output pushin rear? And if so, did you beef it up at all? Curious cause this is way different than anything you usually see.
jrock
46&2
Quote from: Sparkplug on December 12, 2010, 01:26:15 PM
I likewise saw it recently on Pirate and I am impressed to say the least. Can't wait to see this one finished.
Yota87Truck
what's the pirate link? i searched but could not find it.
86bobbedtoy
BoG-ToY
I would hope he used something like supra 8" diffs? as they would just be a little more beef then IFS diffs, as well as he SHOULD be able to set them up to run reverse cut gears? also could run ARB or other locking diffs running an 8" supra diff?
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
mosebilt
Quote from: BoG-ToY on December 12, 2010, 08:10:58 PM
yes...supra diffs...
yjay
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
BoG-ToY
what will they run for lockers? and are they gonna run reverse cut gears for a regular LC HP front end?
twistedtoy92
yota4x4sc
sweet cant wit for more pics!! lookin good
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
BoG-ToY
Im digging the torsion bars, floating air bumps and are those air shocks? or just regular shocks? does the tortion bars do all the work?
swapped89
Awesome build man :thumbs: Cant wait to see it in action!!  :beerchug:
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
GJToyotabug
TAGGED!
should be very interesting.
questions: i see a torsion system. have you figured your spring rate yet? just seems like alot of stress on them with that long of an arm. are those the diffs your planning on using or just mock up?
muddytaco
95 tacoma 5" revtek/bilstein detroit locked 9" with drilled and slotted rotors front and back, 8000# mile marker winch, 16" crager crawlers, too much other crap to mention
96 t100 2wd (soon to be sasd i hope) - dead
85 efi 4runner
01 sequoia
89DLX
Nice, can't wait to see more of this one :thumbs:
1989 Longbed 22re, SAS, camping rig. (sold) Very sad day.
Denver, Colorado.
mosebilt
#20
we are actually making 3 of these...one tundra v8/automatic, one 22r 5 speed and one 5 speed ls-1/truck bodied...Supra diffs on the v8 cars, IFS 7.5 on the 22r propane powered one....im making new hub/spindle design right now...my car uses the torsions with 3 tube by-pass/emusion/air bump...22r car uses torsions as well...with bilstein 5100 shocks.
mosebilt
 :inthedark:
87hillbillyoter
nice work man! subscribed for sure!
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
BUDDERS
Wow, can't wait to see the end product
mosebilt
spindle/upright update...changed it up...new unit bearing, rotor and double shear top and bottom, plus i am machining the bosses so that they hold the 3/4" nut and you dont have to put a wrench on it....and more clearance for the cv boot as well....
zippo
If you see it, its for sale.
BoG-ToY
so, this is a weird question, but are these gonna be rock crawlers or speed machine dune buggies?
mosebilt
BUDDERS
Are these buggies for KOH or just for the hell of it?
