Where to start on a 97 tacoma to make a good dependable ride
Started by Wmpinkerton, November 30, 2010, 10:21:45 AM
Wmpinkerton
I am looking to build my 97 tacoma ext cab for a good play truck but dont want to be broke down all the time due to factory parts breaking Where would be a good place to start Any ideas would be great.
tanabuse
well it depends on how much u wanna dump into her i say if ur broke stay wit what toyota put factory in those trucks ive seen stock list ifs tacos do vary well so weld the rear and go beating
Turning
Over after
Years
Of
Trail
Aabuse
Yota87Truck
Is your truck currently stock?  If so I think a 2.5" spacer lift up front, or coilovers if you can afford it and AAL in the rear w/ 33's is a good start.  Body protection is also always a good investment.
Wmpinkerton
my truck is still stock with a set of 31" kumhos They do really good. I have rectenly found out that body protection is a must ofter meeting up with a few trees that dont move very easy. I would like to change the gearing in the truck and put about a 6" lift on it and then put 33" tires on it  Does any body have any sugestions on a lift that wouldnt break the bank and i was reading about gearing and it looks like 4:88 is a good choice.
Thanks for the comments.
81yotalove
you definitely do not need 6 inch lift to fit 33's. stick with a 10.50 wide and some pinch weld bashing i think you can make it fit. also if you have 16 inch rims use 255/85 r16 tires. a lot tacos use that size when still ifs.
81 swb 22re 35's
Yota87Truck
you should post up some pictures of your tacoma, and what kind of budget are you thinking about?
