Author Topic: Bad T case Vibe  (Read 1399 times)
snowplow
  • Male Posts: 257
  • Member since Aug '06
  • smoke tires not drugs
Bad T case Vibe
« on: Nov 23, 2010, 10:54:19 AM »
Hey dudes, I am getting a bad intermittent vibration from what I think is the tcase when I go above 40mph in 4 hi.
I have an NP435 trans (granny 4 speed) with an A/A to the toyota topshift tcase. I just rebuilt it with marlin 4.7 gears and there rebuild kit. It was my first rebuild, but it went really easy and I felt very confident about it. It also has a FROR  twinstick.
The vibe goes away when I put it into 2wd with the hubs still locked. I believe this rules out the transmission and the front driveline (cause the vibe would still be there). Has to be the Tcase. The only thing I can think of is to check the fluid level  :rivers:
Does this ring a bell to any of you?
Dustin
snowplow [OP]
  • Male Posts: 257
Re: Bad T case Vibe
« Reply #1 on: Nov 24, 2010, 07:21:16 AM »
BUMP! -and make that above 25mph in 4 hi. Nothing in 4 low, nothing in 2 hi or low. It also doesn't seem to be related to being under load.
I searched and got nothing  :headscratch:  Really nobody's ever had a tcase vibe!?  :help:
If I just screwed up a bearing or something wouldn't it whine all the time?
« Last Edit: Nov 24, 2010, 07:27:36 AM by snowplow »
Lowspot
  • Male Posts: 8
  • Member since Oct '10
Re: Bad T case Vibe
« Reply #2 on: Nov 30, 2010, 07:53:42 PM »
Is your front drive line indexed right if you have it lined up wrong you will get a funny vibe
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
Re: Bad T case Vibe
« Reply #3 on: Nov 30, 2010, 09:49:46 PM »
check the drive line x2
GreenYoterKrawler
  • Turtle Points: -4
  • Male Posts: 225
  • Member since Sep '10
Re: Bad T case Vibe
« Reply #4 on: Dec 01, 2010, 06:41:16 PM »
Tripl that, front drive line is binding. mine did that forever till i put a w56 in  :willynilly:
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Bad T case Vibe
« Reply #5 on: Dec 01, 2010, 08:00:50 PM »
Also remember that front drive lines are not always balanced and with a CV joint (which is recommended with a dual case setup), and are greatly affected by suspension lift. Despite using 2WD with the hubs engaged, if there is no torque transmitting through the line its possible to not bind, shake and rattle, which may yield a false diagnosis.
To be absolutely sure it isn't the front drive line, its best to just remove it all together and then drive in 2WD with the hubs engaged.
Mike
snowplow [OP]
  • Male Posts: 257
Re: Bad T case Vibe
« Reply #6 on: Dec 02, 2010, 09:02:45 PM »
Thats a great idea. I'll take it for a spin when I pull it out to change the joint.  :thumbs:
Last post Nov 20, 2005, 05:19:12 PM
by Marlin
Last post Jan 05, 2006, 05:12:51 PM
by BirfMark
Last post Mar 02, 2006, 11:08:54 PM
by toysfreak
Last post Mar 14, 2007, 08:38:44 PM
by rscalmo
Last post Aug 13, 2008, 08:55:24 PM
by focushere
