turning fj60 axles
Started by FBM, November 07, 2010, 07:45:12 PM
FBM
I just need some information about cutting and turning toyota axles
how much do i move them :turtle:
yjay
My preference for larger tires(33's and up) is 5 or 6 degrees negative caster at the knuckle in relation to the ground. If you are running a cv type front driveline you can also rotate the pinion up towards the transfer case a few degrees at the same time to get it away from obstacles and reduce the angle.
Say sayonara to death wobble and bad tire wear  :thumbs:
As a side note, welcome and tell us about you and your project at the new member check in. Click here   http://board.marlincrawler.com/index.php?board=7.0
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
