Starter issue
Started by 91 ex-cab, November 06, 2010, 02:59:21 PM
91 ex-cab
My taco will just click once or twice before starting up perfectly. I don't think it is the starter though, cause my 91 does the same thing and it has a freshly rebuilt starter.
Any thoughts on this :dunno:
emsvitil
Check/clean the battery/cable connections
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
91 ex-cab
Quote from: emsvitil on November 06, 2010, 03:00:48 PM
Oh that was another thing I was gonna say, the battery connections are smothered in red grease. Could this be the issue? I have never seen this before. I have heard of putting a small amount on to prevent corrosion but they are both completely packed.
junya92toy
You can use grease, but it has to be a special de=electric grease. CHeck the connections, but its prob the battery if the starter is new. try to jump it.
91 ex-cab
I'll have to try jumping the battery, sorry if that wasn't clear but I have 2 trucks doing the same thing one with a fresh starter and one with an unknown starter. Someone told me it is probably the starter relay :dunno:
junya92toy
Its prob the starter contacts not the relay. WHere did you get the "new or rebuilt" starters? usually the remans off the shelf are crap. Its best to replace the contacts yourself
91 ex-cab
Got the tacoma worked out, it was just the battery :smack: Still gotta work on the 91 though. The starter was rebuilt by one of my friends.
junya92toy
locked 4x4
that clicking sound is usually the sign of a bad battery or connection.
91 ex-cab
junya92toy
that clicking is usually a sign of when the contacts go bad too
True, or the ring on the plunger.  Mine does it and the contacts are worn but not too bad, but the ring is beat to snot so it misses 4-6 times before finally catching.
junya92toy
ya the plunger can go bad too, can you just get that or are you forced to get a new starter?
I was told at the local toy dealer that you couldn't just get a plunger, but know somebody who works at another toy dealer in parts and they said it can be a pita to track down, but you can get it.  Also heard you can get them at kragen/oreilly, and I've seen them in rebuild kits on ebay.
junya92toy
emsvitil
I put the plunger in my drill press and put a file against the copper to clean it up...........
There's plenty of copper to work with.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
