One of a kind Ford Courier / Toyota Crawler SoCal
Started by EarlKann, November 04, 2010, 08:40:59 PM
EarlKann
Price reduced, motivated to move.  I already think that I could make more parting it out, I just want to avoid the work it would involve.
$7200 including the trailer and all my spare parts .
Spare parts include: tie rod & drag link, knuckles/spindles/hubs/hardware, a CNC cutting brake including all the brake lines and fittings to install it, calipers, starters, spring bushings, stock t-case output, two grills, all kinds of stuff!
$6800 for the truck and the spares, I'll keep the trailer.
$6500 for just the truck.  I'll leave the winch and the ARB compressor that it needs, but keep the race radio and the spare parts.
I will consider trades if I think that they have a realistic resale value equivalent to the prices posted.
Here is the most up to date picture with the cage painted.  I have about 9-cans of color matched paint in spray cans in case a fender or door needs to be replaced in the future.  If you're worried about getting replacement sheet metal, I usually see one or two of these trucks each time I make a junk yard run.  Shouldn't bee that much of a problem.
There are many pictures of my entire build in my photobucket album.
http://s52.photobucket.com/albums/g26/earlkann/Courier/
1973 Ford Courier mounted to an 82/83 Toyota 4x4 frame.  I did it myself, but it's well done, not a total hack job.
22RE stripped down and swapped to a carb manifold to run the GotPropane system.  Mounts for two tanks in the bed, three steel propane tanks included.
GM 100amp 1-wire alternator on ToolBoxGuy mount.
Headman header, new exhaust.
Summit aluminum radiator.
New Optima yellow top.
New Willwood brake and clutch master cylinders.
Trans is a freshly rebuilt Marlin L52HD with billet short throw shifter.
Dual transfercases with Marlin MC07 adapter.
Rear case has new Trail Gear 4.7 gear set and twin stick (not shown in pictures)
Front Range t-case disconnect for front digs.
I have a CNC cutting brake and all the lines/fittings to install it, but not in there yet.
Two Afco manual line locks for parking brake.
Modified TG tcase mount/skid plate.
Both front/rear driveshafts just rebuilt with long travel splines.
Front axle is a stock 84/85 housing.
Low pinion 4cyl 5.29 with ARB locker.
Longfield 30-spline shafts.  (still need to get some Longfield hub gears)
Outers completely rebuilt with new bearings, Marlin axle seals, Front Range ARP high steer studs/nuts.
Sky offroad widening kit.
TG diff armor, unknown vendor truss, Marlin knuckle gussets/shock mounts.
IFS calipers and FJ rotors.
Marlin Crawler high steer.
Rebuilt IFS box, drilled and tapped.
Trail Gear hydro assist ram.  Stock pump drilled out.  Have a PS cooler that isn't installed yet.
Front suspension AllPro 4" springs.
Bilstien 12" shocks
Shock hoops, dropped front hanger.
Rear axle is stock IFS housing and shafts.
V6 5.29 ARB locker
GM Monte Carlo disk brake conversion.
Rear suspension I was told they were Marlin 5" "import" springs, but they clamps say Betts on them.
Bilstien 14" shocks.
5 36x13.50x15 IROKS on black steel wheels.  4 are used but good condition, spare is like new.
Interior has PRP +2" Daily driver seats.  Back of cab is cut out for leg room.
Rear 36" PRP bench mounted in the bed.  Bed floor has been cut out to lower the seat maintaining head room for back seat passengers.
4 new DJ Safey harnesses with 2" padded shoulders and 3" lap belts + sub.
Exo cage built by certified welder.  Mostly all 1.5 DOM with a few pieces of HREW in there.
Kenwood 2-meter "race radio" with magnet mount antennae.
Warn M8000 winch.
It still needs:
ARB compressor mounted/plumbed.  I cracked the tank on the ARB compressor, parts are in to fix it, just have to get it done.
Floor boards finished.  Front has some rust and holes for clearance.  Back seat needs floors fabricated.
Seat belt mounts for back seat.
Winch solenoid pack mounted.  Winch cables hooked up.
Cutting brake installed.  Rear brakes are currently hooked up and drive-able.
I'm sure there may be some other stuff.  Rock lights, some wiring for the wipers to work, etc...
Truck is currently street registered and legal.
Located in San Jacinto, SoCal.
87hillbillyoter
wow that is beautiful and definitely one of a kind. hats off to you and your work. too bad i dont have the money...
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
Rockdad
 ??? Why man why? I saw the build and all of the work you put into it.
TacoRunner's 3 & 4 Link Systems
http://www.4wheelunderground.com/
Ready for any trail adventure you throw at it!
EarlKann
Quote from: Rockdad on November 04, 2010, 08:52:18 PM
While it is street legal, it isn't really a daily driver.  In order to use it as it was designed I would still need to buy a tow rig & camper or an RV.  Even if I had the money for that (which I don't) I'd rather use the money use the money to pay down bills and still have something cool that can be my daily driver.  Looking to get an old hot rod pickup.  Found out at work that they are considering privatizing (I work for the gov) so I need to be prepared in case I loose my job.
Rockdad
Sorry to hear it. That is a really cool truck. I hope someone can give it a good home.
EarlKann
Got some bids on ebay, but no sale.  Re-listed it again for three days.  If nothing happens soon I'm going to have to start parting it o :down:ut.
motormouth559
Man nice build .. you bought a 1st gen off me with dual cases out of Fresno ca about 4 years ago well anyways clean rig good luck with sale.
EarlKann
Thanks,   Yeah, this one is a little nicer than that 1st gen.  :yesnod:
It ended up getting parted out.  I didn't keep really close track, there may be something left of it in my Courier.   :greengrin:
motormouth559
lol ya i don't think its even in the same range as that Courier lol beautiful truck man !
EarlKann
Quote from: deans87 on November 22, 2010, 07:39:29 PM
i got a 72 fj55 wanna trade
Not interested in any more wheeling rigs, thanks though.
kenny5150
really like what you have done to this rig very awsume!!!!!
kenny hines 5150
EarlKann
Quote from: kenny5150 on December 20, 2010, 11:13:25 AM
Thanks,
Just finalized a deal on the sale the other day.  Going up north to 12-Volt Guy.  He runs the Con and goes to the Marlin Crawler Roundup so you guys up north might see it there next year.
Sparkplug
haha nice, we see it around up here then, bad ass truck
kenny5150
kenny hines 5150
Hottrod81
Quote from: EarlKann on December 20, 2010, 11:17:36 AM
Thanks,
He will probably sell it before he wheels it!
