Egr crap
Started by franky112665, November 03, 2010, 01:42:11 PM
franky112665
I know this topic is talked about alot. I've read alot on pros and cons about the system. I want to eliminate vac lines and clutter. Question what happens to the engine if you don't have it on there? I know the state laws,so I want to know will my engine survive without it?
superyota
I didn't feel any difference with mine when i disconnected the egr.  As long as you remember to put it back on for smog, it should be fine.  I plugged mine off temorarily because the egr valve was plugged up and not working.  never noticed any change in performance or fuel economy.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
franky112665
Don't have to worry about smog test here. Doesn't get checked. Is it okay just to plug vac lines or do I need to remove it and seal it off
jackson58
I do not have any vac lines and mine runs just fine. :clap2:
Dirt is for wheelin not for wearin you filthy hippie!
zippo
It's easy to make some block off plates. And then take her off and plug the vac lines. As it gets older they can cause more problems then it helps. All it does is at highway speeds it dumps some exhaust back into the cylinder and reburns it. Enjoy!
If you see it, its for sale.
boneyard customs
Did the same to my 22RE. Removed all the clutter on top the valave cover. Eliminated the egr valve, built block off plates and WAMMO!! Runs AWESOME!!
Dr Phat
I took the tubes that came out of the the exhaust manifold and cut the tubes and had my buddy fill them with his TiG welder. Had no interest in trying to figure out how to make my EGR work with propane injection. Haha, luckily NY has no emission standards on cars/trucks older than 25 years hehe.
GreenYoterKrawler
I wish california would eaze up on it, 25 yrs and older should be a federal standard. china burns coal, and we breath it in the next day is my egr really going to make a difference
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
