GJToyotabug's Desert prerunner build
Started by GJToyotabug, October 27, 2010, 08:26:49 PM
Quote from: GJToyotabug on January 16, 2011, 08:08:26 PM
Yup!!! It's only 50 lbs heavier than the 22re
which trans you going to run? blah blah.... lets get the downlow.
46&2
GJToyotabug
its getting this
http://cgi.ebay.com/ebaymotors/1uz-1uzfe-toyota-Bellhousing-R150-R151-R154-gearbox-_W0QQcmdZViewItemQQhashZitem4155cfa783QQitemZ280612546435QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
will bolt it to sock r151 trans and t-case for now till i can get one built.
itll run a mega squirt 2 ecu, going to do a full ignition setup probably msd. engine mounts will be custom along with headers. their wont be any work done to the engine, the import version has plunty of power plus i want it to be reliable unlike the 22re that makes up its own mind on when and how it wants to run.
so for now just stock piling. as you can see the flywheel clutch bellhousing is quiet expensive!!!! so probably a few months
GJToyotabug
Megasquirt is AMAZING!
Can't wait to see you start this swap up Josh. great choice.
GJToyotabug
lets see i need to update? Yeah I do.  Stay tuned tonight their will be some updates!
steveco.
i thought JD fab was outta business.. if anything theres always TC always reliable
Let's put a smile on that face!
GJToyotabug
JD is still up and running its the other one, i cant remember the name.
ok update! I've been stock piling!
first off bell housing!
Im very happy with the quality! much better than the stupid adapter plate crap.
Got bored so i found the paint scheme for the engine
other than that ive been busy taking care of myself and keeping the 22re running till i can get the rest.
KDXSR5
What? Nothing about your broken motor mount?
GJToyotabug
OH YEAH!!!!!! soo el toddo (KDXSR5) came on through town and i thought I'd treat him to some go fast fury!!!! running the test loop in the desert. Everything was going fine running about 45mph through a pretty well whooped out section and all of a sudden the shifter rips out of my hand! now thats just not right! so we stop, i look in the fender and sure enough i ripped the ears off the frame!!!!!!! the bullet proof motor mounts were perfect! the stock frame just couldn't hold up!
golana
Quote from: GJToyotabug on March 23, 2011, 09:57:00 PM
holy crap dude!!! never heard of that happening before! any pics?
-Steve
1994 4Runner - BUILD THREAD
5VZ-FE - 12" Lift - High Steer - Hydraulic Assist - IFS Mod - Scuba Mod - Ford Fuel Tank - E-Fan - Doubler = 96.31:1 Crawl Ratio
Brake setup
FRONT: 98 Tacoma Rotors/Brake Master Cylinder/Booster, 94 V6 Pickup Calipers, 86 IFS Hubs
REAR: 85 Solid axle Rotors/Calipers/Lug Studs, 1/4" Wheel Spacer
GJToyotabug
no and i'm to embarresed to show my booger welds on it just think of each ear ripping off next to the horn it sits on.
KDXSR5
