Author Topic: shock problems  (Read 854 times)
lil yota
  • Male Posts: 26
  • Member since Oct '10
  • IF IT AINT BROKE FIX IT BEFORE IT IS HAHA!!!!!
shock problems
« on: Oct 12, 2010, 04:18:22 PM »
i need to figure out how to match shocks with a lift
DON'T STRESS IT!!!!
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Re: shock problems
« Reply #1 on: Oct 12, 2010, 04:48:15 PM »
measure from your mounting point on the axle, to where your shock hoop mount will be.  then look at the measurements of the 10,12, and 14 in shocks compressed and extended and try to get one that falls in the middle.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
Re: shock problems
« Reply #2 on: Oct 12, 2010, 11:41:52 PM »
If you are running leaf springs,
Disassemble your spring pack and make a mock up pack with some scrap steel so that with the main leaf attached, its the same thickness as the real spring pack. Bolt it to the axle. This will give you a really soft spring rate and allow you to cycle the suspension full up and down, measure the amount of travel you have at the location you want to put the shock and then choose a shock accordingly.   :beerchug:
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Last post Apr 29, 2004, 01:33:55 AM
by GRM
Air shock advice!
Last post Dec 05, 2004, 12:19:01 PM
by Mike D
Last post Mar 25, 2005, 12:18:27 AM
by mr4x42u
Last post Apr 22, 2007, 08:17:28 PM
by Duffil
Last post Jul 13, 2009, 09:14:08 PM
by REG535
