Sokoji's Mercedes turbo diesel swap/DD build up thing
Started by sokoji, October 09, 2010, 11:22:59 PM
bigarms23
sokoji
Quoteso i didnt know you lived in milwaukie intill i saw this http://portland.craigslist.org/clc/cto/2213131137.html on craigs list. where in milwaukie are you?? im next to rowe middle school
Your on the other side of 224 from me, I'm right off of railroad ave.
Quotesellin it already?
It was just a moment of weakness, I have decided I will keep both my 1st gens.
1981 SR5 4x4 Longbed
83 Crawler
what other first gen do you have? i have a 83 and iv never seen a first gen in milwaukie
sokoji
I just picked up a 79 long bed. Its pretty rough right now and not running but it would be hard to miss.
83 Crawler
that was on craigs list FOREVER!!!! for like 700 bucks right?
sokoji
Yeap thats the one, probably should have passed on it but I have a soft spot for first gens
83 Crawler
Quote from: sokoji on February 18, 2011, 08:43:10 AM
i agree my girl friend bought a 80 4wd origanal onwer  for 250 bucks!!!
but id like to come out and cheak out this truck since i live so close and have never seen it
sokoji
Quotei agree my girl friend bought a 80 4wd origanal onwer  for 250 bucks!!!
Damn, thats a great deal where do you find deals like that? Yeah anytime you want to come take a look.
sokoji
Wow, thats a in really nice condition too, I guess I should just look around more before buying :_oops:
83 Crawler
i paid 1700 for mine  :shake: but you have a PM my friend  :yesnod:
sokoji
Hey did you buy your 83 from the guy that worked at the  oil can Henry in west Linn?
83 Crawler
no i didnt but im really good friends with him, he had a white 4runner right?
sokoji
He might have I just remember seeing that camo pickup and white 4runner at the oil can when I looked through your build pictures.
83 Crawler
yup i bought it then drove it. to his work to have everything changed and flush and to show him. how do you know him?
sokoji
I don't know him, but I lived in the apartments right behind the oil can henrys and walked by those toyotas quite a few times. I was just curious if I was right.
wakkjobb
What year Benz was the engine from? There's a 1980 300SD locally for $800 (400k+ miles, still runs) with the same engine I'm trying to get since I don't have enough cubic feet of cash to build my hybrid. I'd like to know the specs for the engine plate, bushing and anything else that you had to make for this. The oil-burner will be going into my 84 so there's a little more room in the engine bay; probably won't have to mod the hood like you did.
>>Dan
sokoji
Yeah mine was out of a 83 with 260k miles for $400. I don't really have all that many specs that I can remember, I think I used 5/16 steel for the adapter but if I was to do it again I would use 1/4. There was a spacer ring that was on the Mercedes flywheel that comes off, just gave it to the machine shop and told them to drill the 6 holes in the Toyota flywheel. The bushing is pretty self explanatory, just look at the pics I posted I think it was only like 1~1.5" long.
QuoteThe oil-burner will be going into my 84 so there's a little more room in the engine bay; probably won't have to mod the hood like you did.
Its not so much the fact that the engine is long its that the om617 is a front sump and with hysteer the oilpan and steering is competing for the same space. A 2~3" body lift will help alot I still might go that route.
wakkjobb
Awesome; that adapter plate looks thicker than 5/16"... I was thinking like 1/2" for beefiness. Do you know if it's possible to make that oil pan a rear-sump? I have hi-steer and a 2" body lift (that I am planning on taking off)... or could the engine mounts be raised a tad?
Thanks a ton!
>>Dan
83 Crawler
if you ever need help with your first gens just let me know  :thumbs:
sokoji
I don't know a lot about these diesels yet, but from a glance it wouldn't be possible because the oil pump and pickup are chain driven and all that gearing and crap protrude pretty deep into the oilpan. See that's exactly what I did, I mounted it high enough so it would clear the steering but then its sticking out above your hood line. Right now I'm kicking the idea of pushing the engine back 18" to clear the steering and the axle.
46&2
Quote from: sokoji on February 20, 2011, 08:43:42 PM
If you ran the OM617 with the 4x4 Labs steering, would it eliminate the high steer/oil pan issue?
sokoji
Just first glance I would have to say it would have many of the same issues. I'll take some pictures tomorrow to show what I'm talking about. Maybe there is something simple I'm overlooking. The problem would be even worse if you had springs that moved your axle forward, that is why I went with the wagoneer springs.
46&2
This is from the Lab's OM617 conversion FAQ:
Quote12. Any top or bottom clearance issues?
Rough dimensions are- Length 33.5″ back of valve cover to front of fan, Depth 27″ top of valve cover to bottom of oil pan, Width 14.5″ widest part of oil pan. The OM617 has a front sump oil pan so there may be some differential interference on spring under 4wd rigs. Note: We are developing a dry sump oiling system for this engine so the oil pan can be shortened up considerably. With a dry sump system you can flip upside down and still be running without damage to the engine. This will be advantageous for the off road market since rollovers are relatively common.
Might be worth calling them to see if this ever made it to development.
sokoji
Yeah I'll have to check that out, afraid to find out how much they would want though.
sokoji
Here's how close the steering is to the the oil pan.
wakkjobb
Looks kinda close... is your axle stock location or forward? Mine's moving 2-3 forward this month.
sokoji
Mine's stock location, I knew the steering would be close that is why I didn't got with RUFS.
wakkjobb
Hm... and the RUFs are ready to go too. Might have to re-think this whole deal... lame.
