1985 4 runner Sacramento, CA $5500
Started by 844x4, October 01, 2010, 09:47:42 AM
844x4
If you are into wheeling this is the rig for you! Everyone says this but its true, having a second Baby and don't think I'll be able to use this as much as I should.
This is an 85 last year of straight axle and first yr of fuel injection. Top is removable for great fun in the summer! The motor, transmission and transfer case (4.7 to 1) were all rebuilt recently by Davez offroad performance in the last year and have less than 5k miles since. The truck has 5.29 gears in the axles and a detriot locker in the rear and a locrite in front. Tires are 33 inch super swampers with plenty of good tread left. Also has Steel braided brake lines all around. The truck is outfitted with Marlin front and rear bumpers with a new warn m8000 winch. The winch is wound with masterpull winch line which is lighter and stronger than cable and hasn't been used once and always covered. The rocksliders are by trail gear. Rear springs are 63" chevy's with double shackles and rancho shocks all the way around. On the inside is a dual shifter nice becuase it allows you to shift in and out of 4x4 and hi low and allows low range 2wd as well., a nice steering wheel a radio and a cb with nice new whip antenna. The truck includes 2 ammo cans! One ammo can in used for a center console and can be locked to keep your goodies safe when the top is off! The other is in the rear and holds tools and other trail accessories. Along with the truck you will get a hi-lift jack, spare tire and air compressor for those air downs on the trail and a winch accessory kit with gloves, chain tree saver snatch block etc. This truck is clean for a rock crawler but has its dings and dents. I will also throw in everything you need for hi-steer, I have marlin hi-steer kit un-installed which includes the gear box and an axle gusset kit and front u bolt flip kit this is worth $800 in parts. Asking $5500 OBO sacrifice condsidering I'm into this thing for over 8k!! No lowballers or scammers.
If you would like to find out more call, or Text Morgan 916-477-0380
It takes a long time to achieve "instant" success.
Bender
Good luck man.  This second baby business is tough!   I totally understand where you're coming from. :yesnod:
844x4
atzstng
Greiner
844x4
No AC.  I may be able to get some interior pics up this weekend.  Its clean inside for its age, brown and tan interior, sr5 guage cluster.  Everything works.
844x4
Sold!!!  Thanks for looking everyone!!
kenny5150
would you want a 1970 ford bronco on 39.5 irok s
kenny hines 5150
NorCalToy
Quote from: 844x4 on October 08, 2010, 08:08:21 PM
Quote from: kenny5150 on December 22, 2010, 11:20:06 PM
Have you considered reading before posting? and maybe looking at dates on the posts you keep pulling up?
:flamer: IFS
844x4
Hahahahhaha!  I would like a bronco!  Too bad I sold that truck 2 months ago!  LOL
