Author Topic: Tire Groover Anyone  (Read 8757 times)
84krawler
  • Turtle Points: 108
  • Male Posts: 177
  • Member since Jan '10
Tire Groover Anyone
« on: Aug 28, 2010, 12:36:15 AM »
Is there a way to make a tire Groover or anyone have any pics of tires they've grooved?
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
Re: Tire Groover Anyone
« Reply #1 on: Aug 28, 2010, 05:30:34 PM »
Speedaway motors has a good but cheap one for the circle track guys.  I have one and have used it to freshen up factory sipes and grooves with a 1/8 inch knife.  You could do alot more with bigger knives.
– Steve McQueen
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #2 on: Aug 28, 2010, 07:54:28 PM »
i have been dink'n round with my arc welder and some ground down sawzall blades... seems to work decently but i need to figure something tougher out to hold the blade. i will post a vid or something when i make it work...
depending on what you need you could always do what i did to my old boggers.... use a wood chesil or make your own.. heat... remove tread... repeat
took me 15 min to do the outside tread on a 33" bogger... so i figure 30 min a bogger.... will be faster now that i made two, so i can heat one while i cut with another.....
made the tool out of a old bent sami leaf spring i had layn round
Those are some huge welds!
Tillamook, OR
kombatics
  • Turtle Points: -33
  • Member since Sep '10
« Reply #3 on: Sep 01, 2010, 02:17:06 PM »
How hot are you getting It?
GloNDark
  • Turtle Points: -1
  • Male Posts: 282
  • Member since Nov '03
« Reply #4 on: Sep 01, 2010, 04:06:05 PM »
I bought an ideal groover used off of ebay a few years back. Picked it up for $25, bought some new blades for it and have been happy ever since. I grooved all 4 of my 38's in under an hour.
You can pick up new blades and heads off ebay for pretty cheap too.
Used:
http://cgi.ebay.com/ebaymotors/IDEAL-125-TIRE-GROOVER-RACE-CAR-TRUCK-TREAD-REGROOVER-_W0QQcmdZViewItemQQhashZitem35abe63bddQQitemZ230517259229QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Brand new:
http://cgi.ebay.com/ebaymotors/New-XTREME-Hoosier-Tire-Cutter-GROOVER-KIT-w-24-BLADES-_W0QQcmdZViewItemQQhashZitem1c1536816bQQitemZ120614977899QQptZRaceQ5fCarQ5fParts
sweetmeat
  • Turtle Points: -13
  • Member since Dec '08
  • Friends don't let friends join the sierra club
    • Wrecked4x4
« Reply #5 on: Sep 01, 2010, 08:25:40 PM »
Not sure who makes it but we have a tire groover that we use to cut our 37inch bfg projects for our class1 car that we race. Amazing how much it helps. Don't have any pics of the tires though
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
« Reply #6 on: Sep 01, 2010, 10:26:41 PM »
just using a propane torch like this.....
just aim it down and put the chisel under it and let warm for a couple.... not glowing or nothing.... a 5 min preheat would do good. then cut a couple then go back for a min then another couple lugs... thats why i made another one.. just lay it under the heat while your cutting the other one..
here is a vid i found that made me do this.. and yes ... it works that fast... cept i musta got mine hotter cause mine cut better....(maybe mine was sharper)
<a href="http://www.youtube.com/v/IGNPjp0Feq4?fs=1&amp;amp;hl=en_US" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/IGNPjp0Feq4?fs=1&amp;amp;hl=en_US</a>
every place i have been, they have said especially on tsl's that it makes the tire perform so much better.... i dont doubt it as those big tread blocks can finally flex now.....
i just want to be able to get some more tread/life out of my tires.... so i need a groover to take the rubber down to the skin...
sorta like these infamous tires
« Last Edit: Sep 01, 2010, 10:37:01 PM by bleakhorizon »
Tillamook, OR
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #7 on: Sep 03, 2010, 09:23:09 AM »
bleakhorizon,  i wouldnt have removed those longer lugs but would have skinned the inner areas to give it a deeper groove
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
« Reply #8 on: Sep 03, 2010, 11:49:30 AM »
One of the best mods you can do to a bogger is remove the small lugs. Aswell as V cut the bigger blocks
Do you need a Hammer?
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
« Reply #9 on: Sep 03, 2010, 12:27:19 PM »
yea.... i only took the short ones off... the pic above is from a thread on the PBB... the guy who owns fatgirl had a new buggy made and had those cut boggers on it...
Im prob just gona buy the cheap tire groover so i can cut more into the base rubber and make the tread blocks "deeper".... if i destroy a tire its not a big deal... i got em for freeeeeeee :) lol
Tillamook, OR
Last post Dec 15, 2003, 08:53:37 AM
by BMFN_TOY
Last post Apr 24, 2005, 06:01:17 AM
by 79coyotefrg
Last post Sep 20, 2005, 05:36:38 AM
by guywithuglyyota
Last post May 10, 2006, 02:09:56 PM
by Bazzi
Last post Jul 21, 2008, 02:12:57 PM
by KDXSR5
